Where To Put The Nozzle?
Old Feb 2, 2003 | 05:40 PM
J G's Avatar
J G
Default Where To Put The Nozzle?
I'm installing my NX wet kit right now an an 02 z28... Where is the best place to put the nozzle? Does it need to be in a certain place or what? where are ou guys putting them?
Thanks
Old Feb 2, 2003 | 11:44 PM
CAT3's Avatar
Restricted User
Default Re: Where To Put The Nozzle?
Dril it in about a 1/2 to 3/4 inch in front of the TB, making sure the spray hole is pointed towards the TB. doesnt matter if you go in from the side or top/bottom. get it as far centered inside the bellow as possible and make sure no air can seep in around the nozzle nut and nozzle assembly. Good-luck.
Charlie.
Old Feb 3, 2003 | 12:12 AM
ZEIK 383's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by J G:
<strong> I'm installing my NX wet kit right now an an 02 z28... Where is the best place to put the nozzle? Does it need to be in a certain place or what? where are ou guys putting them?
Thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can drill a hole in the lip of your MAF sensor[just large enough for the nozzle to pass through]and then the bellows, and then notch a half circle in the clamp. Make sure you're between the TB and the MAF. This allows for a very rigid installation of the nozzle. I've been doing it on the passenger side at 9 o'clock........has worked well for me! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
