LS3 block. How much N20
Old Dec 9, 2013 | 04:36 PM
Roger Blackmore's Avatar
Default LS3 block. How much N20
Some of you will have seen this in YB. I thought I would post it here also. Looking for input from engine builders, or from people that have sprayed big shots. I know there are several people running this block in real street spraying 250 worth. I'm wondering if the block will take 400, without going through extreme machine work like an ERL block gets.
Thanks
Roger
Old Dec 10, 2013 | 01:23 PM
87silverbullet's Avatar
I don't see why not when some guys have put close to that on weaker ls1 blocks.
Old Dec 10, 2013 | 02:50 PM
BigEd_72455's Avatar
It is possible to do it but you had better be damn accurate on the jet sizes. Are you wanting run a plate or go pro fogger? For that HP level it would be more accurate to just go pro fogger. You are also talking running plugs that are 8 steps colder than stock for this much nitrous. I don't have a clue what that plug number would be either. But surely it can be found somewhere online.
When it comes to the fuel side, a dedicated pump is pretty much a must have, and the nitrous feed side can not be less than -6AN for the feed. You will need a good Y adapter to feed both nitrous solenoids as close to evenly as possible.
When you plan to make your first full good pass, use a full bottle that is around 1000 psi. Just under is ideal, usually 950. Much higher than that and you risk locking a solenoid up. After your pass, close the bottle as soon as possible. When you get back into the pits, pull the bottle out and weigh it. If you use more than 4 pounds of nitrous on a single pass, buy a couple extra bottles, or buy 2 15 pounders. They are actually easy to come by for $100-150 each for used ones.
Old Dec 10, 2013 | 02:52 PM
Oh, I forgot one little thing, if you have a nitrous backfire at that level of nitrous, you will have a BOMB for an intake assembly. You better get a full face helmet like a simpson that has an impact resistant face shield.
Old Dec 11, 2013 | 10:35 AM
Randy WS6's Avatar
I run a DP 250 wet & 250 dry = 500. on a LS3 board out to 4.090" 431cid.
heres a little pic of my setup
Old Dec 11, 2013 | 10:43 AM
Nice. How many passes have you sprayed 500 on? And are you spraying both kits from early in the pass?
Old Dec 11, 2013 | 01:17 PM
Talking
That is just insane. What is the engine combo you are running that on as well?
I hate to say this, but for the first time at 42 years old, I have nitrous envy!! LOL
Old Dec 11, 2013 | 01:22 PM
NnOoSsSs's Avatar
Gotta love when its done right
Old Dec 11, 2013 | 03:19 PM
ATVracr's Avatar
LMFAO !!!
Rookies!
Old Dec 11, 2013 | 03:23 PM
ATVracr's Avatar
You mean like this ...
Old Dec 11, 2013 | 03:29 PM
Lol. Had me a smaller version of that this year.
Old Dec 11, 2013 | 03:31 PM
That must of been right at the release of the TB.
Don't y'all miss nitrous??
Old Dec 11, 2013 | 03:52 PM
ATVracr's Avatar
Ya .. can sorta see the tire smoke.
Big tune up spun right into the limiter and Boom goes the hood scoop !... 30' in the air LOL !!
Nope !
Old Dec 11, 2013 | 07:02 PM
Nope !
Ouch. Did it do any damage to the motor?
Old Dec 11, 2013 | 07:30 PM
silverls1z28ofdeath's Avatar
I guess I'll be finding out as I am doing a 416 factory aluminum ls3 block for a 250....ish shot lol
Old Dec 11, 2013 | 08:10 PM
Randy WS6's Avatar
The engine is a LS3 stroked to a 431cid.4800 stall, 4l80,9"ford 4.22 gears
Old Dec 11, 2013 | 10:19 PM
camscam02's Avatar
LMFAO !!!
Rookies!
Hahahaha I just about died reading that, had to log in and comment on that one
Old Dec 11, 2013 | 10:31 PM
LMFAO !!!
Rookies!
What is that about? I don't really see anything wrong with what was said?
If you want to talk ****, send me a PM about it and lets talk.. You put rookies on here and then don't elaborate why you are downing my comments just, to me anyways, means you cant justify what you are ridiculing.
Old Dec 12, 2013 | 08:42 AM
in for the show
Old Dec 12, 2013 | 08:47 AM
ATVracr's Avatar
No, with the dry kit we have backfired it a few times and it has never hurt anything other than the scoop that one time.
Car starts right back up and drives ... makes the plugs black but we changed them just about every pass anyways.
