Looking for 8.60-8.80@3200lbs. 6.0L Iron Block, 408 stroker w/nN2O. What other Parts?
Peter - thanks for the compliments. It was an iron block 5.3 with stock ls1 crank. Compstar rods, diamond nitrous pistons, dart 225 heads worked over by strokerta, around 12.5:1 comp. Hyd roller custom grind cam from legend racing and bullet. Stock rockers lifters etc. Would go 10.50's on hp. Hope this helps, good luck, I've since stepped out of the stock cube stuff and have a 6.0 on boost. Lemme know if you have any more questions, feel free to pm me.
What did you shift that thing at? I'm going back and forth right now on staying hyd roller or going solid on my new tfs 245's and mast 4500. I shifted last year at 7300 and crossed the 1/4 at 7450 but she was well done at that point. I went from 3.89 to 3.80 this year.
With the hydraulic roller, the Super Vic 4150, and a Quick Fuel 850 it pulled hard to 7,800..
We had a 3.90 gear with 28's, would go through the traps about 8,000..
Lots of good info in here.
What intake do the LS7 heads like?
http://www.hotrod.com/techarticles/e...top_ls7_heads/
There actually a 12 degree angle. And OP I'm actually building a 416 nitrous motor with these gen x 255 heads with a Cnc nitrous port from TEA on them. I can't wait to see how my setup turns out.
Op, I don't see why you can't run the numbers you want if you have a well spec'd out combo. I tuned a customer's car to a 9.14@149 on an old school 406 sbc with AFR 210 eliminator heads and 11:1 compression in a 3200 lb car. It still had more left in it but the owner of the car wanted to do some changes to the car and start back with it this year. The motor only dyno'd 563 hp at the crank
Thanks for all the posts guys, lots of good info here.
I'm pretty set on the GenX 255 heads, from all the reading I've done and I'm not ready to step into the Mast intake world and the high end heads with the high price tags.
silverls1z28ofdeath I'll PM to talk about the heads and motor stuff, thanks for chiming in man.
01 blue SS, that 406 motor, how much spray was being put to it to go 9.14?
Thanks again guys.
Thanks again guys.
Thanks again guys.
Thanks again guys.
As for that 406 it had 2 stages on it and the 1st stage was a 65 jet and the 2nd was an 82 jet. Both stages were tuned very soft with timing pulled more than needed. 1 stage went 1.34 60ft and ran a 9.57 out the back door. that stage had more in it and so did the second. The car had 3.73 gears with a 28x10 slick with a 4000 Coan racing nitrous stall. I wish i could of leaned on it more but I wasn't the owner for the car so I guess we will have to wait to see.
#33
If you can't build a 408 with those gen-x heads that goes 8.60's, something is wrong... Those are some bad *** heads, I would have someone chamber soften them if you plan to run a higher compression ratio and really get after the tune up.
Otherwise most LS engines are VERY sensitive to timing.
#34
This is one of them things that I'll believe it when I see it. Even some of the people at Edelbrock don't know about the intake. When you call them they don't know anything. Mike@ S-K speed said that his contact said that it will be out by May. Again, I'll see it when I believe it.
#36
#39
Shouldn't need anything too excessive, we went 8.9X's with a 347 on an 82 jet in a plate..
I think a well built 408, even at 3,200 will go mid 8's with around a 200 "shot"..
I am finishing a Trans Am right now with a 408, CNC LSA head from AI.. Holley Hi-Ram, Holley EFI, Induction Solutions dual dry foggers.. It should be over 3200lbs and I think it should go far into the 8's..
#40
And there is a unicorn tied up in my back yard.
Mike@sk speed said his edelbrock contact said may and one of the guys from edelbrock said later in the summer. As i said before, I'll believe it when it hits the market. This is just like when Wilson said they were going to make that special LS intake that they never made.
