Holley HP EFI Engine Control Units 550-603
yes, All Holley HP/Dominator/Avenger systems do a nitrous system...
Wet
Dry
Wet Progressive
Dry Progressive
up to 4 stages plus a purge (assuming you have enough available outputs for it)
the HP has 4 outputs, which could be used to trigger a relay for Nitrous.
and it works Dam well with a Dry kit...
I ran a 500 Dry shot with no issues other than Traction.
Wet
Dry
Wet Progressive
Dry Progressive
Wet
Dry
Wet Progressive
Dry Progressive
Wet
Dry
Wet Progressive
Dry Progressive
no... I use a Dominator...
the Avenger / HP / Dominator are the same software...only differences are total inputs and outputs..
and again...
and again...
Wet
Dry
Wet Progressive
Dry Progressive
Wet
Dry
Wet Progressive
Dry Progressive
