Need to learn Everything about using GAS on a LS1 !!!!
Old Mar 5, 2003 | 09:25 AM
John98LS1's Avatar
Default Need to learn Everything about using GAS on a LS1 !!!!
I have a 98 z-28, i have a spec stage 3 clutch with adj 02 master and 02 slave,other mods are in my sig. I have the stock 10-bolt with 3.42's, no suspension stuff yet.( will soon). I will be going with a wet kit 100-150hp, when is it a safe point that i can hit the GAS? I will be running Mickey ET street's 26-10.5-15. what safty stuff do I need??? and what GAS stuff do i need (like bottle heater,gagues, etc) Thanks for all the help.
<small>[ March 05, 2003, 09:42 AM: Message edited by: coolguy ]</small>
Old Mar 5, 2003 | 11:40 AM
Bad Habit Bird's Avatar
Default Re: Need to learn Everything about using GAS on a LS1 !!!!
Here is a link that could be helpful to you.
Nitrous FAQ
<small>[ March 05, 2003, 11:42 AM: Message edited by: Bad Habit Bird ]</small>
Old Mar 5, 2003 | 02:41 PM
C4VetteLS1's Avatar
Hmmm never heard if it called "GAS" before...but oh well.
Id say you get a TNT F1 Kit ( i can sell you one for $550 new). Then get a MSD Rpm activated switch $70-90 bucks. Make sure its WOT switch operated.
If you have a chance spray it the first time on the dyno and tune it on there.
Old Mar 5, 2003 | 04:30 PM
If after reading that you still have more questions maybe you should be a little more specific about what exactly it is you want to know.
Old Mar 5, 2003 | 10:39 PM
John98LS1's Avatar
I want to know the safest why to run N2O on a stock bolt on motor. thanks
Old Mar 6, 2003 | 12:40 AM
John98LS1's Avatar
read that already, knew that stuff already, need more help! thanks
Old Mar 6, 2003 | 01:03 PM
John98LS1's Avatar
Old Mar 6, 2003 | 01:18 PM
Tony TNT's Avatar
Dont get greedy! Stay with 75-100hp I would get a window switch and a fpss too.
On the ls1 I prefer wet. Both NX and TNT are great choices for that.
If you go the dry route try TNT or NOS.
Old Mar 7, 2003 | 06:00 AM
spanktu's Avatar
I have always called it "GAS"
"spray"
"juice" that is Old school
I would spray coming into second gear
espcially with a M6, your rear end will live longer
window switch would be nice but not needed if you are consistent driver"dont want to hit the rev limiter while in the GAS".
bottle heater for a more consistent bottle pressure, I believe NX has a pressure transducer
in their kit.
that sould start you off for a small shot 100-150
<small>[ March 07, 2003, 06:51 AM: Message edited by: spanktu ]</small>
Old Mar 8, 2003 | 02:42 AM
John98LS1's Avatar
