ls9 cam with nitrous????
Old Mar 30, 2014 | 08:20 PM
danielblackst1's Avatar
Default ls9 cam with nitrous????
I have a 98 f body with 01 long block(241heads). I bought a ls9 cam and want to run nitrous outlet plate kit. I've been thinking of advancing the cam a few degrees to bring the power range down some when not spraying. How far advanced can I install this cam? The way I understand it, cams with overlap are susceptible to reversion. Is my cam with negative overlap still susceptible? I was wanting to advance the cam more than ordinary (6+deg.)
Im stuck with this cam for now so I want to set it up to work as well as it can. Ill be swapping to 5.3 heads (706) that should put me close to 11-1. This is my whole setup:
01 ls1 stock
Ported 706 heads shaved ~.020
ls9 cam
1.8 rr
25% underdrive
150 shot nitrous outlet plate kit
long tube 1 7/8 3" collector
Any technical advice will be appreciated.
Old Mar 30, 2014 | 08:40 PM
Rise of the Phoenix's Avatar
No need to do anything with that cam but install it straight up. That baby cam aint going to sufer down low. And not sure what you mean about overlap. Tons of guys running nitrous with 10+ degrees of overlap and making killer power, running fast *** ET's all while doing it safe.
Old Mar 30, 2014 | 09:34 PM
HCI2000SS's Avatar
I agree with Pheonix here. Sounds like you should just go with a different cam
Old Mar 31, 2014 | 07:18 AM
advancing a cam too far that has overlap ground into it can cause reversion, maybe im making a mountain out of a mole hill and reversion won't happen till I get into the 10*+ range
Old Mar 31, 2014 | 07:26 AM
Yeah I should have picked a different cam. It was a bunch of mistakes all in a row with my credit card lol. If I can set it up and still get good torque out of it then that will be fine. Ive been reading that the ls9 cam loses as much as 40 ft lbs down low and doesn't catch up until 4500. My high compression may make up for some of that idk. Looking for expert cam advice.
Old Mar 31, 2014 | 08:08 AM
What are the specs of the LS9 cam? My 227/235 110 LSA cam doesn't feel like it lost anything down low, and then comes on like a raped ape around 4 grand. I have no before dyno numbers, but the dyno graph shows looks right on par, in regards to low end torque, to what other bolt on LS1's put down.
Old Mar 31, 2014 | 08:10 AM
.552/.558 211/230@.050 122.5lca 122icl from what I've read
Old Mar 31, 2014 | 08:13 AM
I don't see how, with a good tuner, that cam loses much down low.
Old Mar 31, 2014 | 01:06 PM
I believe I'll be getting the tuning done at vengeance racing by mike carnahan.
Old Mar 31, 2014 | 03:46 PM
That cam should be very easy to dial in, especially for pros like the guys at Vengeance.
Old Mar 31, 2014 | 04:04 PM
87silverbullet's Avatar
If I'm swapping a cam in and getting a tune done, there is no way in hell that I am putting an LS9 cam in my motor. Unless you live in Cali nor something for smog but even then there are good cams that still can pass a sniffer test.
Old Mar 31, 2014 | 04:09 PM
that's good to know. Thanks for the $.02
Old Apr 1, 2014 | 08:33 PM
Im stuck with what I have for right now so I'm trying to make the best of it.
Old Apr 2, 2014 | 12:28 PM
Sell that cam for 100 bucks and I have a Magic stick 3 I can sell you that I never used for $250.
Old Apr 2, 2014 | 10:38 PM
I don't have the springs for an ms3 so thats another added cost. Ms3 is over .600 lift right. If I remember correctly.
Old Apr 2, 2014 | 11:01 PM
where are you located and do you know if that cam is nitrous friendly?
Old Apr 3, 2014 | 06:41 AM
Many guys have used it for nitrous use on here and if I remember correctly the moderator Camscam had an ms3 in his car and went low 9's with it. It's at my shop right now. The cam was supposed to go in an ls1 for a customer and he was going to hit it with a healthy dose of nitrous but plans changed and he decided to build a stroker.
Old Apr 3, 2014 | 07:06 AM
HCI2000SS's Avatar
With small to moderate shots of nitrous almost any cam will be just fine on nitrous. No need to be concerned about "nitrous friendly" cams at this level
Old Apr 3, 2014 | 06:10 PM
Kip Fabre's Avatar
If you advance this cam to + 6 or 8 it would not hurt. I think it will help.
Old Apr 4, 2014 | 12:30 PM
I agree with you on that one. Heck, I wish I'd have gone bigger than the cam I have now that it's all said and done.
