Nitrous Express Direct Port Install
Old Apr 3, 2014 | 03:52 PM
corvette8189's Avatar
Default Nitrous Express Direct Port Install
Nitrous Express Direct Port Install on my 08 ZO6
I wanted something that looked as well as it performed. So I called up my good friends at NX. After discussing my wants and needs they came up with this four solenoid direct port system, which i think looks awesome.
Why NX?
Made in the USA, Technical help is just a call away, the best customer service I've ever had, and the quality and value of the products they sell. If you need anything Nitrous give them a call.
I'm running the Maximizer 4 progressive nitrous controller mounted in the glove box. This controller can do everything from rpm, tps, mph, time, boost, and afr correction.
I wanted a nice clean install so i ran all the wires to the ecm.
tps- C2 Pin 63
rpm-C1 Pin 48
vss- C1 Pin 57
I ran all the wires and nitrous line through the firewall behind the dry sump tank.
Bottle is mounted behind the passenger seat where i can turn it on if the need arises and also hidden when the hatch is shut.
Some finished pictures
Old Apr 3, 2014 | 05:39 PM
streetlegalls1's Avatar
Nothing like 8 NX nozzles,that system looks great and your correct about NX,a great company and second to none on the product also
Old Apr 3, 2014 | 09:42 PM
1320king's Avatar
hey that's a really trick fuel fitting on the rail! Killer looking setup
Old Apr 4, 2014 | 06:02 PM
Rise of the Phoenix's Avatar
Very nice. How much you planning on spraying?
Old Apr 5, 2014 | 12:57 PM
Detoxx03's Avatar
Nice looking setup
Old Apr 5, 2014 | 04:24 PM
Thanks guys
Old Apr 5, 2014 | 06:15 PM
Is your Vette the one in the new GM High Tech mag? If so, did Justin tune the car at MC Racing?
Old Apr 6, 2014 | 02:26 PM
i wish but that one is not mine
