NX Jet sizes?
Old Apr 24, 2003 | 10:54 PM
Zangel's Avatar
Fiery Features Director
Default NX Jet sizes?
I am looking for the Jet sizes for the LS1 NX wet kit. I need the nitrous and fuel jet combo for a 100 and 150 shot.
Old Apr 24, 2003 | 11:02 PM
TXSSycho's Avatar
Default Re: NX Jet sizes?
100 shot 52/31
150 shot 62/33
Old Apr 25, 2003 | 02:32 AM
fastls1inaz's Avatar
I have jet sizes for 175,200,250 if you need them! <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Apr 25, 2003 | 02:48 AM
broke7's Avatar
What are the ones for 175 if I get brave?? Im guessing a 67/35-37?
I have 57/31 for 125 shot
62/33 for 150 but I have found 62/35 works best for me
Good Luck
Old Apr 25, 2003 | 03:54 AM
well here are the #'s straight from nx I probly run my system diffrent than some of you but I'll give you guy's the #'s
@5psi N20 fuel
150 62 57
175 73 62
@10psi N20 fuel
100 52 38
150 62 46
175 73 52
200 78 57
250 88 62
Hope that helps some of you out,I have turned some very good numbers with this kit,nos big shot sol,nx shark nozzle.
Old Apr 25, 2003 | 07:25 AM
Zangel's Avatar
Thank you very much!
Old Apr 25, 2003 | 10:52 PM
Big Rick's Avatar
@5psi N20 fuel
150 62 57
175 73 62
@10psi N20 fuel
100 52 38
150 62 46
175 73 52
200 78 57
250 88 62
I think those jet sizes are for a carb's system.
Old Apr 26, 2003 | 12:36 AM
Actually no they are for a efi application,Like I said prior I run my system a little diffrent.I use the fuel rail into a holley carb regulator,then from there I run a fuel pressure gauge on the regulator,then I can regulate fuel pressure going to the nozzle almost like a carb setup.No matter what you have to regulate fuel pressure to the fuel side of a nozzle or plate.Nx recommends you flow the system at 5psi or 10psi,I found out that you need a bigger pump(255lph)to run 10psi.
This setup has worked very well for me and I have set it up on all of my friends efi mustangs and my buddie just ran his wed nite it ran 14.30@99mph on motor and 12.40@116mph on a 150hp letting out at the 990'.So to each his own but it works well for me.Hope that sheds some light,If you need pics I will be more than happy to email a pic or 2 if anybody else wants to try it!
Old Apr 30, 2003 | 09:00 AM
Hunter98's Avatar
Good Luck
Are those definitely the correct sizes for the 125 shot? I really would like to know because I have never seen them before.
Thanks!
