does this mean my noid is stuck open?
i have tested my wiring twice already and everything checks out.
When i went to test it for the first time, as soon as i oppened the bottle the car started stuttering so i shut it off real quick. tough to myself i fucked up my wiring and im sending 12v to the noids as soon as i switch my arming switch on.
But thats not the case. so i pulled my air intake off the throttle body and slightly oppened my bottle with the car off and no keys in it and it sprayed....
im guessing my brand new solenoid is stuck open? very happy i didnt blow my intake open when it sprayed the first time whit engine running, kinda wasting my bottle testing this pos
the fuel noid isnt spraying unwantedly tough, my tank would be empty by now and it would smell like crazyif this can be of any help, im using nx wot switch with msd window switch
il google a bit later going to the track... all motor lol
Did you buy this new from us? There should be a filter in the inlet fitting on the nitrous solenoid to prevent it from catching trash and hanging up. If you want to send the box into us we would be happy to take care of you. You can shine a flashlight in the inlet fitting on the box, there should be a filter down in there if you bought it new from us. Without filters it could definitely cause your solenoid to hang open if something gets caught up in the piston. (Debris from the mother bottles etc.)
-Garrett
-Garrett
was all sealed (had the sealing sticker on the side)
I will go chec it with a flash light and get back to you asap.
this is an actual pic of wat i received
i am not using any tefflon on my lines, only have some on my pressure gauge.
-Garrett
