Nos mini controller setup
Old Oct 7, 2014 | 10:18 PM
ra79428's Avatar
Default Nos mini controller setup
My controller is reading r2. Does anyone know how to get it to read rr?
Old Oct 8, 2014 | 01:31 AM
03EBZ06's Avatar
its LIVE on channel 2! Just figure out why its live and fix it, TPS, RPM, etc.
Old Oct 8, 2014 | 07:22 AM
ra79428's Avatar
I didn't hook up anything to channel 2.
Old Oct 8, 2014 | 09:26 AM
brandon@nitrousoutlet's Avatar
You have the parameters in the controller configured so that it is trying to fire the 2nd channel. Run through the controller settings and move the 2nd stage activation rpm up out of the usable range.
Old Oct 8, 2014 | 09:54 AM
ra79428's Avatar
Ok, I will try that tonight, thank you
Old Oct 8, 2014 | 10:32 AM
ra79428's Avatar
What do you recommend i change the settings to on channel 2 so that it won't come on?
Old Oct 9, 2014 | 01:36 AM
03EBZ06's Avatar
set ACTIVATION RPM = 9900.
Old Jan 4, 2015 | 10:26 PM
BoinaVerde's Avatar
Yea, I know, old thread, but thought I'd post in case someone winds up here looking for an answer like I did. I had the same issue with the controller getting stuck showing r2 when I too had nothing set on the second channel. Changing the activation rpm to 9900 did not work for me. I finally changed the Throttle Position Activation Switch (TPAS) setting for channel two from 01 (hot WOT switch) to 00 (grounded WOT switch). I left the channel 1 TPAS setting at 01. This fixed it for me, YMMV.
