major dumbass move
Old Oct 24, 2014 | 07:19 PM
JP's Avatar
JP
Off Topic...But I believe your American Flag is hung wrong.
Old Oct 25, 2014 | 10:05 AM
stroked383HSR's Avatar
how so?
Old Oct 25, 2014 | 10:45 AM
Originally Posted by GIMPY02
ok I had a backfire like this happen before and it didn't only Crack the intake it actually blew the entire backside of the intake off destroying the map sensor and oil pressure sensor . I'll bet urs is blown out also...
well i think you called it
I opened up the throttle body and looked with a flashlight and i can see my firewall on the other side.
so the intake is ruined
jeez! what a fuc up I did. haha!!!
Old Oct 25, 2014 | 07:41 PM
maroonls1z's Avatar
Might as well get a fast and direct port since it's off haha
Old Oct 25, 2014 | 08:13 PM
GIMPY02's Avatar
Or a single plane with a direct port since he needs a new hood to
Old Oct 25, 2014 | 11:13 PM
JP's Avatar
JP
Originally Posted by stroked383HSR
how so?
The Union (stars) should be on the left,and while your at it id raise it a little higher then the Confederate flag.
I 2nd a direct port
Old Oct 26, 2014 | 09:08 AM
N20zuki's Avatar
The union stars are suppose to lead the way, so it's not a left or right thing. FYI
Post pics of the intake when it come off!
Old Oct 26, 2014 | 10:39 AM
JP's Avatar
JP
They lead off on uniforms,hanging on a wall they are to the observers left,FYI
Old Oct 26, 2014 | 11:59 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Agreed
Op, which way are you leaning for the intake?
Old Oct 28, 2014 | 08:58 AM
maroonls1z's Avatar
I guess this is a time where you could say "you'll blow the welds off your intake" haha! Sorry it's trashed but just an opportunity to build it stronger
Old Nov 3, 2014 | 08:56 PM
Yah pulling that intake off just to look at it and get pics for us is a must
well here is it....rear blown to shiit.
I got question?
whats the weather pack im pointing at? I cant find a plug to go into it.
did that come off the old ls1 intake and not used anymore?
also,
I know i need a oil pressure switch....what other sensors do i need?
whats under my hand? does that come with the new intake?
Old Nov 3, 2014 | 10:17 PM
  #32
Zmg00camaross's Avatar
Under your hand looks to be the MAP sensor.
Old Nov 3, 2014 | 10:34 PM
  #33
68shortwide's Avatar
Jesus. Glad you're aight, I'm with the other guy, always wondered what lay under a ws6 hood lol I'm in agreement with gettin a fast intake. Real tempted to get one for mine but cant justify the expense. Good luck man.
Old Nov 4, 2014 | 01:21 AM
  #34
Werewolf SS's Avatar
In the last picture the connector you are pointing at is the Cam Sensor.
It drops into a hole in the block and picks up the rotation of the cam, using this info along with the crank sensor it can determine both rpm as well as where the engine is at for the proper timing and firing order.
Unless your block was converted to a 58x due to the cam sensor being placed in the front of the timing cover (only on newer gen iV engines, ls3 and such.) and that sensor is just there to fill the hole, (very unlikely.).
You may have blown the connector off and if so that would prevent it from firing when turning over as the PCM can not determine when to fire spark or spray the injectors.
Old Nov 4, 2014 | 01:23 AM
  #35
The connector may have fallen under the tranny tunnel and you'll have to fish it out if it was blown off. It has a bit of wire from the harness allowing it to move around if free. Check under the tranny tunnel if you haven't found the connector Or follow all wires coming off the main loom of the harness to see if you can find it (or what is left of it).
Old Nov 4, 2014 | 01:40 AM
  #36
kelsey_canard's Avatar
I would rep that carnage proudly.
Old Nov 9, 2014 | 10:21 PM
  #37
WSTEXAS's Avatar
wow that must have been ******* insane to go through glad you ok and the bottle didnt go boom
Old Nov 9, 2014 | 10:49 PM
  #38
99Bluz28's Avatar
That sucks, but sounds like lady luck was still looking out for you since it could have been a lot worse.
IMO, put a BBK SSI intake on there. Then if that ever happened again you'd likely only have to remove the bottom panel and hammer it flat and reinstall it.
Old Nov 11, 2014 | 02:40 AM
  #39
35th SS's Avatar
wow lucky bottle didn't go boom.
Old Nov 13, 2014 | 05:33 PM
  #40
dannyz's Avatar
Bottle's have burst disk's. Scare the hell out of you, but no explosion.
