Rings for nitrous
Old Nov 18, 2014 | 03:31 PM
454navyss's Avatar
Default Rings for nitrous
What rings should I run in my 5.3? I want to run a 300-400 shot through it.
Also, someone school me about ring gap for nitrous.
Old Nov 18, 2014 | 05:23 PM
454navyss's Avatar
It is going to be using factory pistons and will be on the track 90% of the time. Just in case yall need to know that
Old Nov 19, 2014 | 01:52 PM
WE TODD DID's Avatar
Stock rings will be fine once gapped accordingly.
Old Nov 19, 2014 | 02:38 PM
86Z28USAF's Avatar
http://www.aa1car.com/library/ring_end_gap.htm
heres an article i found ill keep lookin lmk if it helps
Old Nov 19, 2014 | 02:40 PM
86Z28USAF's Avatar
http://www.jepistons.com/PDFs/TechCo...instrc2618.pdf
http://www.cp-carrillo.com/LinkClick...Ls%3D&tabid=74
These seem a little more helpful good luck
Old Nov 19, 2014 | 03:44 PM
brandon@nitrousoutlet's Avatar
I've always stuck to (.0070XBore) top and (.0075XBore) bottom.
Old Nov 19, 2014 | 03:45 PM
FEAR LS's Avatar
Factory pistons... what about the rest of the assembly? I ask, because if you're using stock rotating assembly, I would'nt even bother. You'll be in there again before you know it..lol
Old Nov 19, 2014 | 04:52 PM
454navyss's Avatar
Thank you for the info.
The rest of the rotating assembly will be stock too, I'm doing this just to get the car running, if it only lasts me a few months I'll be happy as long as I can get some seat time
Old Nov 19, 2014 | 04:59 PM
93camaro_zzz's Avatar
What kind of vehicle is it going in?
Old Nov 19, 2014 | 06:43 PM
454navyss's Avatar
86 camaro
Old Nov 20, 2014 | 06:29 PM
Rodney WS6's Avatar
What is the weak point in the 5.3 engine? Rods? Pistons? I've had people give me a "good luck" look when I've told them I want to spray 250 to my stock bottom end 5.3
Old Nov 20, 2014 | 06:37 PM
"MAC"'s Avatar
I thought the 5.3s could hold it considering a lot of people are doing that for junk yard turbo builds?
Old Nov 20, 2014 | 06:39 PM
Rodney WS6's Avatar
That's what I don't understand. I've seen a few people now mention that a 5.3 should be sprayed no more than 200hp on stock internals...yet you read all day long about these "junkyard 5.3 1000hp turbo" builds...I don't get it?
Old Nov 20, 2014 | 07:07 PM
"MAC"'s Avatar
Probably has something to do with how the stress is being forced on the internals. Or maybe the ring gaps wish i knew but im definitely gonna stick around and find out lol
Old Nov 20, 2014 | 08:54 PM
FIVEPOINT7's Avatar
Nitrous is harder on the internals than boost IIRC.
Old Nov 21, 2014 | 11:27 AM
454navyss's Avatar
Nitrous is harder on internals than a turbo but I guess I'll see if it will hold a 300+ shot
Old Nov 21, 2014 | 11:47 AM
Its all in the tune. We have customers hitting 5.3's with 400+. Will it last? I don't know. Has it been done? Sure. As far as what is safe for us to recommend, 200 is about it. Like I said it takes a spot on tune up to make it work.
Old Nov 25, 2014 | 07:25 PM
Doug G's Avatar
Just remember that Nitrous is like a sledgehammer hitting the pistons where "Boost" (turbo/SC) increases as the rpms go up....much easier on parts in comparison.
Old Nov 26, 2014 | 03:42 AM
Rodney WS6's Avatar
Off topic. I remember reading somewhere your car is Ford Redfire Metallic, do you know what color primer they used? Grey, red? It looks great!
Old Nov 26, 2014 | 07:05 AM
That is not at all true.
