Timing retard with high octane?
Old Nov 29, 2014 | 03:32 PM
95TAVERT's Avatar
Default Timing retard with high octane?
Hi guys and gals, I started putting together my nitrous setup and was wondering if I need to pull timing with a stand alone fuel tank and 103? 150 shot max on a forged 383 with AFR heads. I think I am going with the Mini progressive, but thought if I spent money on stand alone I might not have to pull timing or at least not as much? I have HP tuner so I can pull a couple degrees with out and trouble, it's not a daily driver but I hate to pull 4 degrees and drive when not using the bottle. Any real world experience would be much appreciated.
Old Nov 29, 2014 | 06:55 PM
FIVEPOINT7's Avatar
Is the car tuned for 103? And I don't think you'll notice 4 degrees in the seat of the pants-o-meter but your motor will notice knock if you leave it. I'd just pull the timing.
Old Nov 29, 2014 | 07:26 PM
95TAVERT's Avatar
It's tuned for 93, the 103 will be for stand alone with nitrous application only.
Old Nov 30, 2014 | 06:51 AM
Doug G's Avatar
Adding nitrous, pull the timing when on the juice and tune it.
Old Dec 1, 2014 | 09:57 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Best to do this. The higher octane will help you be able to run more timing, but its better to start with 2* per 50hp pulled, and tune back into, because its different with every application, depending on compressions ratios and a bunch of other variables.
Better to start safe and tune into it.
-Garrett
Old Dec 5, 2014 | 07:40 PM
gardnertroy's Avatar
Default 103 isn't much
I've been running 93 in the tank and 120+octane. I pull 3 degrees on a 100 shot and 4 degrees on the 150. Instead of your standard 2 per 50hp. But that's my setup. Every car is different. Your car might take more or less timing than mine.etc.
Old Dec 5, 2014 | 11:47 PM
Dynospeed's Avatar
If a stand alone is in the budget run one. We normally run c116 or renegade 120n in the stand alone along with pump gas in the gas tank. On a 100 shot some combos end up with 0-1 pulled while others still like 4 pulled. Now the combo that still wants 3 out would have needed 2-3 more out.
Old Dec 6, 2014 | 08:17 AM
WE TODD DID's Avatar
-Garrett
Seriously, why do you keep telling these people to pull 2 degrees per 50? You don't even know the details of the guy's engine and you're trying to give him a recipe to burn pistons. What if he's running 40 degrees of timing, and he pulls 3 degrees as you're recommending? Are you telling me that 37 degrees of timing is a safe starting point for him?
Old Dec 7, 2014 | 09:29 AM
dekan513's Avatar
its basics. just a starting point. and for a small shot i dont think its gonna matter much. my car has 11* pulled for 150. thats just how it is . but i started with the basic 6* for 150.
if ur questioning what to do. dont just go out and make a long full pass on the bottle. make a quick hit with a clean plug and go from there.
Old Dec 7, 2014 | 10:37 AM
I know what the basics are as I've been tuning nitrous engines for over 10 years. And I'll tell you, I've learned the hard way to figure out what works, and what runs the fastest. A starting point would be to back the timing down more than you think you need, and put it back in as needed. It doesn't matter how much timing you pull; what matters is what the total timing number is with the system on. There are way too many variables to an engine to recommend an across the board amount of timing to "pull". Very bad, and dated advise. I would expect more from a company that designs and sells nitrous systems. You won't hurt a thing by backing the timing down more than you need. There's no sense in starting high on timing and burning pistons and chambers, and beating the bearings out of the engine.
Old Dec 8, 2014 | 09:50 AM
We state in almost every post that that is from a factory timing perspective.. Even pulling 2* from where the motor makes its most N/A power is still on the safe side.
2* per 50hp from a factory timing perspective is very safe for what most of the racer's on here are doing with nitrous, often times more than you need retarded. With a higher compression engine, we recommend running race fuel in conjunction with pulling the recommended amount of timing, to start with, and tuning back into it.
Better to start safe.
-Garrett
Old Dec 8, 2014 | 10:14 AM
Old Dec 10, 2014 | 11:07 PM
SMEC-SS's Avatar
Why are you worried about the timing? Ever heard of the pin56 mod?
Old Dec 19, 2014 | 11:22 PM
95TAVERT's Avatar
I guess I haven't heard of it. I thought I had researched LS nitrous install pretty thorough, but I guess not. What can you tell me? Or where should I look?
Old Dec 20, 2014 | 06:01 AM
krissoto's Avatar
With the higher octane u shouldn't have too pull too much timing, but if u are running an insane amount of timing to squeeze all the hp out of your motor now, u might need to pull more out. Detonation is your enemy and that's where reading plugs come in. And not sure , but the pin 56 trick is where u can wire a resistor in and pull X amount of timing while on the kit. It's a cheap alternative to the lnc 2000. Put a colder plug in it, and sneak up on it. Make a short 1st and half 2nd gear blast and pull over and see what she's doing. Baby steps. Good luck
Old Dec 20, 2014 | 01:12 PM
Killer5.3's Avatar
Like WeToddDid said the best advice is to know your total combo and give a suggested starting point for total timing , correct plug, octane, etc. You didn't say if it was carbed , fuel injected, compression, camshaft, what kit or any other details that may be important. Another thing is if you tuneup is rich it will want more timing to make it try and burn some of the extra fuel out and run halfway decent. Need to make sure you have a good clean base tuneup in the system , correct plug, gap, and safe total timing for a starting point.
Old Dec 25, 2014 | 04:37 PM
95TAVERT's Avatar
Fuel injected with 36 lb Bosch rated @ 43.5 psi running 55ib pressure,11.4 comp Diamond Pistons , 238/246 605/615 Comp, Nitrous outlet 58 mm plate kit, 255 granatelli pump. Ported LT1 intake, Pacesetter LT, 3600 Double DD, 390 9 inch. 24X conversion.
Thanks for any info, my first time with the GAS.
Old Dec 30, 2014 | 09:55 PM
Bowtiedford's Avatar
like they said every combo is different and some use a good safety rule when your new to this. I have a stand alone for my Nitrous and on the first stage I run 150hp and dont pull timing, been like that for years. would I recommend it to try? Nope! My cam has a lot of overlap and its a specific nitrous cam. Many variables to have and consider.
Old Dec 30, 2014 | 10:41 PM
SMEC-SS's Avatar
Pin 56 mod allows you to run max NA timing and then once it sees ground it will operate a custom operating system. I know EFI live supports this. Pretty much in a nutshell you have a second tune for the nitrous where it can retard timing and set your desired A/F ratio for the spray.
I forget of the top of my head, but I think its the red connecter for the PCM. Pull it off the PCM and look for spot 56. Should be empty. Get a pcm pin, some wire and a switch and you will be good to go. If its not the red, then its the blue, but Im almost sure its the red. Run the wire from 56, to one side of the switch and from the other side of the switch, run to ground. That's it in a nutshell
*****, I just read your sig. Car is a LT1?**
Old Dec 31, 2014 | 10:39 AM
MEAN LT1's Avatar
Correct. Hes an LT1 running an LS 411 pcm. Im not sure if the pin 56 mod would work on his application.
