383 ls1 Block. - 400 on a progressive?
Old Feb 25, 2015 | 09:24 AM
Mavn's Avatar
"I MAID THEESE"
Default 383 ls1 Block. - 400 on a progressive?
It's a 383 Wiseco nitrous pistons/hellfire rings. Manley h beam rods. Texas speed forged crank. Arp Everywhere. Can I safely spray a 400 on a progressive direct port with a stand alone and c16 in it?
Old Feb 25, 2015 | 09:26 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
What compression? Rings gapped appropriately? Nitrous cam?
-Garrett
Old Feb 25, 2015 | 09:34 AM
Mavn's Avatar
"I MAID THEESE"
^ 11.5-1 compression. Hellfire rings gapped appropriately . Cam specd for a 400
Old Feb 25, 2015 | 09:46 AM
brandon@nitrousoutlet's Avatar
Are you running C16 in the whole car or just the stand alone?
Old Feb 25, 2015 | 09:56 AM
With you having a dedicated fuel system running C16 your going to be covered for the fueling of the nitrous. Also being you have a dedicated I'd suggest running low pressure for the fuel because low pressure will give more of a fuel adjustment than running a high pressure setup if your regulator is adjustable.
-Chris
Old Feb 25, 2015 | 10:12 AM
Mavn's Avatar
"I MAID THEESE"
Thanks! Don't think the bottom end will have any problems holding that much? - Austin
Old Feb 25, 2015 | 10:32 AM
As long as its built to hold the shot and you run a semi safe tune in theory it should hold no problem. At 400hp you definitely need to have the fueling and the tune correct because if not and you have a hiccup then it could cost you a motor.
-Chris
Old Mar 2, 2015 | 01:06 AM
Detoxx03's Avatar
400 is a good bit and should be fine. I sprayed 250-300 on a similar setup back in 2010.
Old Mar 7, 2015 | 04:22 PM
ATwelveSec02Z28's Avatar
It will probably take 400 worth....
work up slowly from something like 800 to 1000lb/hr of nitrous....Have someone flow your system, you keep the nitrous to fuel ratio right, and the timing low and it will be fine.
