Timing and plug questions. Lnc-2000 mini set up
Old May 3, 2015 | 10:12 PM
game-over's Avatar
Default Timing and plug questions. Lnc-2000 mini set up
I have a ls1 heads cam boltons 42 lb injectors with a 255 walbro pump w/ arp rod bolts. t56 built 12 bolt rear with 373's
On motor it made 425.
I have a nitrous wet outlet 92 plate kit. .
On a 100 hit it made 530 whp.
I used the suggested plugs and gapped them to what nitrous out let calls for.
My nitrous tune...is my all motor tune.
Well. My friends have talked me into a 150+ shot (depending how my fuel looks like).
Well I do a lot of all motor pulls and rarely get up on the spray.
But I really liked the idea of the lingenfelter LCN-2000 so I can retard my timing. For various shots ( 100,125,150, 175 ) .
I've been on this tune now for two years and would like to go back to a solid motor tune and use the box where we see fit.
Any unforeseen problems?
I also Am going to put new plugs In it before it gets on the rollers. Again before I used what was recommended and gapped them accordingly. Should I consider a different gap since I want to bounce between shots.
Note:
I say now I want to bounce between 100 and 150. But I'm sure I'll probably just leave the 150's in.
Any thoughts.
Old May 3, 2015 | 10:31 PM
game-over's Avatar
Old May 4, 2015 | 06:18 AM
HCI2000SS's Avatar
What plugs were you using before? The BR7's gapped around 30 to 35 would be best. I run the LNC-2000 and it works great and pulls the necessary timing when spraying only
Old May 4, 2015 | 08:30 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Normally you want to go 1 step cooler plug per 100hp. NGK makes a 7, 8, and 9 heat range plug for the LS. I would start with your plug gap around .034. You will know if your gap is too wide if the nitrous starts cutting out when you make a hit, this means you are blowing out the spark. If that is the case I would close the gap up to .030-.032.
As mentioned above, I would run the BR7 plug for anything 100-200hp worth of nitrous.
The lingenfelter box is handy to have because it lets you pull timing on the fly, and only when the nitrous system is armed. I would pull 2* per 50hp to start with and tune back into it.
Let me know if you come up with anymore questions!
Thanks,
Garrett
Old May 4, 2015 | 08:23 PM
game-over's Avatar
I was using the ngk br7 ef. Gapped around 35-37 I think.
I see they come out the box at .032 I may just leave them alone.
Any problems with this for my all motor tune/pulls.
I will do about 90% all motor and about 10% on spray.
Old May 4, 2015 | 10:48 PM
NOS LS1's Avatar
Default Fast AFR Monitor / Data Logging
I am Running an LS2 404 ci motor with a 150 shot, BR7EF Plugs, Pulling 6 Degrees of timing out with the LNC - 2000 Timing Retard. Single Walbro 255 LPH Fuel pump. 42 lb. injectors.
I also Run Sunoco 100 Octane & 91 Octane @ 50% mix. I use the Fast A/F Ratio Monitor with Dual Wide Band Oxygen sensors to Tune my Camaro.
Occassionaly Data Logging Full passes at the Drags to check my air / fuel Ratio.
I Run my A/F Ratio on the Rich side 12:1 with No problems.
Old May 5, 2015 | 08:02 AM
.032 Is just fine.
If you come up with any other questions let us know!
-Garrett
Old May 5, 2015 | 10:00 AM
brandon@nitrousoutlet's Avatar
That's going to work just fine.
