Well it's done, LSX DP System by NX.
#43
Cannibal: I agree with the smooth texture coment, I am going to take it to a paint shop and have them do a real thick clear coat and that will give it the smooth look, we did it on my ls6 the same way, it was never sanded and it looks smooth as ice.
98VOBRASVT: If I told you the price I would have to kill you.
.....You can get one for the low price of
$1650!! It only took about 2&1/2 weeks to do.
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#45
That price is the DP kit, which includes everything you need to hook it up, with the uprgaded fuel rails, laser etching, upgraded cylinoids, and plumbing and jets ranging from 200 to 500hp, the intake I bought from TSP.
#56
Looks great!!!! I see where the main nitrous line hooks up to the N20 Noid, but with your purge noid to the left, will the billet fuel be in the way where the fitting normally comes out of the purge noid? Or am I missing something... not sure where your purge line will come from if not from the purge noid? Please advise... thanks!
#57
Actually I noticed that too, it was on the other side, we had a hell of a time getting the plug that fills the purge hole out of the N20 noid, ended up taking the black piece loose, it turned around on us and thats how the purge ended up on that side, I have fixed it now and I will change the pics after the intake gets back from the clearcoating, I turned the noid back around and it sits on the right of the N20 noid now, looks much better and it clears everything!!!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#59
lmfao!!!
Well got the intake on and damn it was a tight fit in there with that dp system and coil relocation, I will ahve some pics up later tonight on my site. Damn I'm tired, I began this install 2 days ago, total of about 28hrs!!! That's got to be a record for an intake install!!!! I can't feel the tips of my fingers.
time for a few of those...
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
