Only had to pull 2 degrees for 150 shot?
Old Jul 31, 2015 | 05:09 PM
Canderson1434's Avatar
Originally Posted by brandon@nitrousoutlet
Man, that plug really looks like it's been driven on. You can see part throttle fueling on it. Was the plug brand new when you did this? The plug needs to be new, have little to no idle time on it and once the pull is over, the car needs to be clicked off immediately. This is the only way to get a correct reading. Is that what you did here?
Well I put the plug in then I had to drive down the road and turn around so when I was at the end of the run I could just shut it off and pull into my buddy's driveway.
