Nitrous outlet 78mm plate
Old Nov 2, 2015 | 06:47 PM
98z28jorge's Avatar
Default Nitrous outlet 78mm plate
I got a question about the jetting I'm seeing jetting for a 200 shot online of 78n 46f but my kit says for a 200 shot it's 78n 35f that looks crazy lean not trying to hurt my motor so any help would be nice before this setup I was running a nos plate with 65n 38f it the car seemed to like it a lot picked up 13 tenths with that setup and and 14mph so it really liked it
Old Nov 3, 2015 | 09:36 AM
AJatNitrousOutlet's Avatar
Depending on when you got your kit, we did narrow the jetting down to get our customers into a closer window for tuning. The jetting on our website is the most up to date and will be the closest as far as tuning goes.
Old Nov 3, 2015 | 10:58 AM
98z28jorge's Avatar
What afr are you guys aiming for with this latest jetting?
Old Nov 3, 2015 | 03:58 PM
The old jetting was rich- too rich. The new jetting is really close to the tuning window, but still a bit conservative on some applications. As far as an AFR you should be targeting- 11.8-12.0 is good and will keep you pretty safe. When calculating jetting we don't use AFR, we use the Nitrous to Fuel ratio.
Old Nov 9, 2015 | 01:06 PM
98z28jorge's Avatar
[QUOTE=AJatNitrousOutlet;19026038]The old jetting was rich- too rich. The new jetting is really close to the tuning window, but still a bit conservative on some applications. As far as an AFR you should be targeting- 11.8-12.0 is good and will keep you pretty safe. When calculating jetting we don't use AFR, we use the Nitrous to Fuel ratio.[/QUOTE
Plate working good Quick update to this build went to the track last night and here are the results n/a and on a 200shot threw a nitrous outlet plate last time out went 10.26@131 on a 150 shot through a nos plate
Old Nov 11, 2015 | 09:52 PM
bjamick's Avatar
Looks like it's running really well.
Old Nov 12, 2015 | 08:59 AM
Looks good! Keep up the work!
Old Nov 13, 2015 | 06:33 AM
98z28jorge's Avatar
Just added a ram air sux2bu style and gonna try to get a anti roll bar hopefully get a 1.3 60ft should get me a 9.90 slip and a maybe 1 or 2 mph
Old Nov 16, 2015 | 06:06 PM
tnmotown's Avatar
I'm curious how much difference that ram air will make. I'm thinking about adding a chrs1313 to see if that helps. I'm almost similar to your times, so I'll go off your studies lol!
Old Feb 24, 2016 | 10:41 AM
98z28jorge's Avatar
Seemed the ram air picked up 2-3 mph on my setup from motor to motor pass but had better weather too went from 118 best to 121 now
Old Feb 24, 2016 | 12:42 PM
tnmotown's Avatar
That's good to hear. I ended up putting one on and do feel a slight improvement. I also added front Viking shocks so it'll be hard to see how much I gain exactly. Trying for 10's with the cam only
Old Feb 25, 2016 | 05:40 AM
98z28jorge's Avatar
It's tough but I don't see why not just gotta set it up rite good luck man
