9 second ET possible?
Old Jun 12, 2004 | 06:58 AM
Flamin Raven's Avatar
Default 9 second ET possible?
I'm currently running a 100shot on top of my H/C setup and have ran a best of 10.56@128 with a 1.55 60ft (not spraying out of the hole). I was looking through the nitrous list and noticed that all the 9.99 or better cars are all on atleast a 200shot. I only need a 5tenths gain and think on a 175shot my car would dip into the 9's. Does anyone else think this is possible?
Old Jun 12, 2004 | 07:11 AM
gator's 99TA's Avatar
that last .5 seconds at that point is extremely difficult. going from 11.00-10.50 you can do with pure hp and tq. to hit 9s, you need real chasis tuning. give it hell though!
Old Jun 12, 2004 | 07:34 AM
Fast SS on TNT's Avatar
I concur. You will have to have mad 60ft times, and more then a 175 shot. No law against trying!
Old Jun 12, 2004 | 08:52 AM
VIl's Avatar
VIl
Lightbulb Plugs with catalyzer...
Try spark plugs with nitrous oxide catalyzer. They are proven to add from 1/3 to 1/2 of nitrous power.
These plugs are avaliable in Russia (my invention) and will soon be sold by NX.
Old Jun 12, 2004 | 09:58 AM
Josh's Avatar
Do you have any more detailed info on these spark plugs?
Josh
Old Jun 12, 2004 | 10:27 AM
BMN's Avatar
BMN
???? interesting ????
Old Jun 12, 2004 | 10:32 AM
masterdill's Avatar
Flamin Raven ignore the ignorance of this topic. Put in some 100 octane, jet it up to 150 and spray it out of the hole.
Old Jun 12, 2004 | 11:08 AM
My plan was to run a 50/50 mix of 93 & 104 and spray it with the 175 right off the line. I think if I could get a mid 1.4 60ft that it'd do it.
Old Jun 12, 2004 | 11:41 AM
wow, um someone is 1) spaming this forum and 2) invented something totally retarded sounding with these nitrous plugs. almost sounds like a joke. nitrous oxide IS a catylist.
Old Jun 12, 2004 | 11:42 AM
masterdill's Avatar
Try to run as much race gas as you can, I try not to mix as much as possible. Try 150 first if you have the jets, then 175. Spraying out of the hole is addicting
Old Jun 12, 2004 | 12:20 PM
BADBOYZ28's Avatar
I say try the 175 out the whole but like everyone said those last 5 tenths are the hardest to gain.. I say with the 200 out the whole with good traction you will be there.
Old Jun 12, 2004 | 04:32 PM
VIl's Avatar
VIl
To Josh & BMN: Some detailed info is on www.sokolniki.com. It starts in russian but it has an english version.
To gator's 99TA: You seem not to know chemistry. N2O is not a catalyzer, but an oxidizer, that starts working only at temperatures near 600 C. It decomposes into nitrogen and oxygen (its volumetric share increases from 21% in air to 33%). Also there are some factors why nirous oxide works, but it takes too long to explain you.
It`s important that using the catalyzer, temperature of N2O decomposition reduces, so N2O starts working earlier.
However, we (and our NX partners) could recieve up to additional 1/3 of nitrous power with these plugs, but our prototype is not perfect, so I hope the addition can be up to 1/2.
Old Jun 12, 2004 | 04:46 PM
383LQ4SS's Avatar
VII...please dont post in this thread unless its about the original topic.
If you want to start another thread and talk more about N20 catalysts and TECHNICAL issues...please do.
Back on topic......
Old Jun 12, 2004 | 04:53 PM
Brian Tooley Racing's Avatar
I went 10.50's on my very first nitrous pass with my car, I had to spray it another 100 shot on a cool day to go 9.80's, but I have a C5. I agree with what others have said, spray it out of the hole, get it in the 1.40's in 60', and you'll be there.
Old Jun 12, 2004 | 05:47 PM
VIl's Avatar
VIl
Back on topic......
OK.
I've only asked a questions...
Old Jun 12, 2004 | 08:36 PM
Nine Finger 02 Z28's Avatar
I have run 10.32@131 with H/C and a 100 shot with 1.43 60ft.And with a 200 shot I ran a 10.04@134 with a 1.45 60ft.I think that you will need more than 175 shot and probably more that just that less weight more mods and maybe.
But it never hurts to try.So go for it.
Old Jun 12, 2004 | 11:59 PM
badass 2002 z28's Avatar
Ninefinger, you only gained 3mph when going from a 100 to 200? Was that still using the stock fuel system? seems like something isn't right
Nitrous catalyzer plugs....mmmkay
Flamin, The only way to find out is to try it out. If the 175 doesn't do it, I think it'll be damn close
Old Jun 13, 2004 | 02:30 AM
My times on the 100 shot are the fastest on the NOS list with a 100 shot.
And I just looked over the Nitrous List and your Screen Name was no where to be seen so that might also have a little to do with your confusion.
And as stated by others in this thread once you are going fast already it is a lot harder to pick up.Also different tracks and times of the year and also on my 10.04 pass that was with 2000+ DA.
And no I highly doubt that the 175 Shot will put the person that started this thread into the 9's.
Old Jun 13, 2004 | 01:49 PM
PREDATOR-Z's Avatar
More power is good! But for serious 9's, you better be ready to shed some weight, and a lot of it. Then hook it all up and there you are. You can break 9's with around 600+ rhp if you have less weight (and I don't mean a stripped tin can) but 3000lbs race weight and traps of 135+
Old Jun 13, 2004 | 02:50 PM
I just want to go 9.99
I don't have all the safety equipment to go any faster
