Fuel Feed from Gauge Adapter
Old Mar 1, 2016 | 09:17 PM
LSFOX's Avatar
Default Fuel Feed from Gauge Adapter
Can I pull fuel for my Nitrous Outlet kit from a 1/8" Gauge adapter?
I there a limit to how much I can safely spray pulling from a port that small?
something like this
Old Mar 2, 2016 | 12:58 PM
AJatNitrousOutlet's Avatar
Do you mean a manifold? If so, that's the part we use on our plate systems made for aftermarket rails. Where are you wanting to pull fuel from?
Old Mar 2, 2016 | 01:05 PM
LSFOX's Avatar
That's what I am looking to do. Its going to go from an aftermarket rail.
Wasn't sure this would flow enough or if I would have to go with a 3 port Y adapter to go to each rail and then to the Fuel solenoid.
My kit was originally for a 90MM plate but I switched intakes and am going with a stinger plate.
Old Mar 2, 2016 | 01:11 PM
You shouldn't have a problem pulling fuel from there depending on how much you're wanting to spray. Nice choice on the Stinger! How much are you looking to put through it?
Old Mar 2, 2016 | 01:46 PM
LSFOX's Avatar
200-250 max. Its a pump gas car.
Old May 11, 2016 | 06:22 AM
thirdcoastangler's Avatar
Default 1/8 NPT Gauge Adapter
Also wondering the fueling limits if supplying the fuel solenoid from a fitting similar to above.
I have an NO plate kit for a FAST intake on a G8 (needed the top nozzles on the plate), and have aftermarket rails.
Old May 11, 2016 | 07:55 PM
jblankenship's Avatar
250 should be easy if the pump is adequate. Look at the recommended jetting compared to 5 years ago. You used to see 63/36 for 150 hit, now a 36 fuel jet is recommended with an 82 nitrous jet. That's 250 per nitrous outlet's jet chart.
