NOS Mini Progressive II Problem
This morning I checked the wiring, and everything is hooked up right. I tested the solenoids and they are fine. I know fuel and nitrous are getting to the solenoids.
Anyone have any input on how to troubleshoot the controller?
To test the controller, turn your bottle off and disconnect it. Then, go into your programming menu and set the rpm start to 0, and leave your WOT setting at WOT. Then, with the car off but the key on you should be able to hear the solenoids click when you push the pedal to the floor. When testing this way you don't want to just hold the gas pedal down for periods of time, because it will still spray fuel unless you disconnect the fuel solenoid. If the solenoid clicks, then you may have a damaged solenoid piston. If it doesn't, then you need to check your wiring again while paying special attention to the grounds. In my experience, the ground is usually where the issue lies in the wiring. Next, go over the programming. Here's a basic setup on a Mini for reference:
F.20
C.00
P.00
1.35
2.61
3.0.0
4.40
5.1.0
6.99
7.00
8.02
9.4.3
I am going to move the ground to the battery itself before I test it again. will also disable the stand alone fuel pump to ensure no fuel is spraying.
