Anyway to wire 2 step to clutch so the nitrous isn't activated when nitrous is armed?
Old Jul 11, 2016 | 10:08 AM
bobby5's Avatar
Default Anyway to wire 2 step to clutch so the nitrous isn't activated when nitrous is armed?
I have my 2 step wired into my clutch and it works great but I'm putting a nitrous outlet wet kit and was wondering is there anyway to wire the 2 step soit isn't activated when I have the clutch in when the 2 step is on at wot?
Old Jul 11, 2016 | 10:26 AM
JoeNova's Avatar
Restricted User
Use a relay. You have a normally closed and normally open terminal on the relay, you can wire it up so the Nitrous and 2 Step are both powered by the same relay and can never be on at the same time.
Old Jul 11, 2016 | 10:30 AM
AJatNitrousOutlet's Avatar
This is exactly what you should do. Wire the relay so that when your 2-step is activated, it removes the ground from your controller or window switch. As soon as the 2-step is turned off, the ground is supplied back to the nitrous system, allowing it to activate.
Old Jul 11, 2016 | 12:02 PM
bobby5's Avatar
Ok thanks alot guys is there a wiring diagram anywhere I could go by that would help out a ton too?
Old Jul 11, 2016 | 12:35 PM
Hardcoresoldier's Avatar
wouldn't that play hell with the controller's progressive ramps and such? I am looking to add some sort of interrupt to mine because I want to start no-lift shifting. Using the MiniProgressive II controller.
Old Jul 12, 2016 | 09:06 AM
It wouldn't mess with the ramp at all, because the progressive isn't spraying while you aren't moving. As soon as the 2 step is let off and the power is supplied to the controller, the progressive activates and the ramp starts on launch.
For no-lift shifting you'd need to run a relay on the clutch switch so that when you press the clutch, it takes the power or ground away from the solenoids and not the controller. That would allow your controller to continue working and resume your program after you shift, and not start over as if you were in 1st gear (depending on how you have ramp pause mode setup (Step P on the controller)).
Old Oct 21, 2018 | 04:53 PM
Mark Woodruff's Avatar
Default Powerglide with button on shifter to activate transbrake and 2 step
Would like more info on how to use a relay to keep from activating my nose microswitch on my carb at WOT
Old Oct 21, 2018 | 05:02 PM
Default Activating the NOS and 2 Step together while staged
Will this cause any damege or is it just a waste of NOS?
Old Oct 23, 2018 | 10:36 AM
brandon@nitrousoutlet's Avatar
Old Oct 23, 2018 | 10:37 AM
You don't want to do that.
Old Dec 8, 2025 | 05:14 AM
chvycmaroz28's Avatar
Ik this thread is old but any chance u have a diagram on how to do this. The lnc2000 and winmax controller is already in the car and working just gotta add the stuff for it being a stick as all the wiring came out of an auto car
