Need help with nx express plate kit
i am installing a nx 78 mm plate kit on my 2000 camaro. im using the intellitronix window switch along with the WOT switch from nx express.also running the nx purge kit. i am in need of a wiring diagram on how to run my wires.
activation switch- one side power, on side ground, middle to purge?
then from purge switch to where?
Ls1tech & Truck Sponsor
If you didn't want to run a complete separate switch for the purge you can run one side of the purge button to the main system arming switch acc prong < Middle one > and the other side of the button goes to the purge noid.
http://www.nitrousexpress.com/oldweb..._solenoids.pdf
-Chris
-Chris
