Which fuel for nitrous????
Note: both fuels are readily available, will most likely order drums.
-Chris
E-85 IS pump gas (Benzine), the lowest grade, then mixed with E-100.
NEVER sure what you get. (E-70/E-85)
Thus "make" your own blend !
Lance
It is not consistent ratio and water content.
So what is good with one tank full may not be on the next.
The VP fuel will be very consistent as long as you keep the can closed.
http://www.vpracingfuels.com/downloa...eet.pdf?inline
http://www.nitrousoutlet.com/gm-98-0...el-system.html
