Looking for Harris Speed Works "The Interface " install tuninģ instructions.
Old Nov 10, 2016 | 10:33 PM
2000ssNX20's Avatar
Default Looking for Harris Speed Works "The Interface " install tuninģ instructions.
As the title say I need the instructions so I can install and adjust this thing. Praying somebody can help me out.
Thanks
Shawn
Old Nov 11, 2016 | 02:00 PM
tug686spd's Avatar
Old Nov 11, 2016 | 02:19 PM
tug686spd's Avatar
If your car is already tuned "DO NOT" go by these recomendations for timing. It is possible possible the tuner did not mess with the timing at the temps the Interface targets but highly unlikely. You'll need to verify what timing is being pulled for each setting before you start spraying. Also in the logs I show a .2-.3 sec delay before timing is pulled when activated so if you plan on spraying bigger shots I'd have it activated when system is armed istead of fired to be safe.
The only logs I have on my computer now are for a Ls2 maf and these are the temps im seeing for the different "degrees to retard" in the setup.
2 degrees= 103 IAT's
3 degrees= 111 IAT's
5 degrees= 122 IAT's
7 degrees= 135 IAT's
Didnt try 9 degrees because I didn't need another column.
Old Nov 11, 2016 | 03:54 PM
2000ssNX20's Avatar
Thanks a TON !!!!
