All New Nitrous Outlet WinMax Window Switch!
Hey everyone, just wanted to let y'all know that the new Nitrous Outlet WinMax Window Switch is ready and on the website! Here's a link to it:
http://www.nitrousoutlet.com/nitrous...t-feature.html
Here's a link to the instructions that show the menus and some more of the features:
http://www.nitrousoutlet.com/media/t...ndowSwitch.pdf
The new WinMax is a dual stage capable window switch with RPM and TPS activation. A few of the things that sets it apart from the others on the market is it can control a timing retard for each stage of nitrous (based on ground activation, so great for you guys running the LNC-2000, etc.). Also, it has a gear lockout feature that can prevent the nitrous from coming on for up to 3 shifts. It's extremely easy to use and the programming menu is in plain english on a brightly lit LCD screen. Also on the face of the window switch is a shift light and 1st and 2nd stage activation indicator lights. This window switch does require the use of external relays though. For more info or to order visit the link or give us a call at 254-848-4300!
It doesn't have an output for an external shift light- but depending on where you mount it, you may not need another. The shift light on the face of the window switch is pretty bright. The brightness can also be adjusted if you need it to be.
http://www.nitrousoutlet.com/media/t...tch%20v1.1.pdf
