Nos mini controller/ 15974 install hiccup
Old May 16, 2017 | 06:31 PM
fathead7466's Avatar
Default Nos mini controller/ 15974 install hiccup
scoured the internet for an install guide. Unable to get my system working with the controller. Need diagram for WOT switch, Progressive controller, relays (if needed), arming switch, and window tuner. Single stage use only. For 68' Camaro w/ rebuilt engine. Will show pics when I get home. any help THX.
Old May 17, 2017 | 09:00 AM
brandon@nitrousoutlet's Avatar
I'm not sure what you mean by window tuner but this diagram should cover most of what you're looking for. Below is a link to the instructions for the NOS Mini. Let us know if you have any other questions.
http://www.nitrousoutlet.com/media/t...e_15974NOS.pdf
Old May 17, 2017 | 09:54 AM
Default NOS mini controller
The little digital tuner for the controller. It has the two buttons with an SSD (seven segment display) for tuning. My apologies. Thx for the help. When this works with the improved time slips, We'll call your boss and tell him you deserve a raise!
Old May 19, 2017 | 05:12 PM
Brandon,
I appreciate your help. Unfortunalely, it didn't work. Holley says that the controller only provides a ground for to trigger solenoids. Solenoids need their own voltage, ch1 (blue) just.provides a ground to complete the.circuit.
Another thing is that I.cant activate the relay to switch voltage according to diagram. 86 12volts present , ground to fpss not completeing circuit for voltage to be present at 87. I think I not wired correctly. Is there another combination I should try?
Fathead7466
Old May 19, 2017 | 05:29 PM
Wh, blue to NO on switch
Green goes to 12v arming
Controller:
Blue to one side of SOLENOID
Grren to tach
White to 12v arming
Relay:
Yellow to 87 on relay
Black gnd to fpss
Blue connects 12. Volts from arming, com on microswitch (12v present), 12v to controller.
Attached Thumbnails Nos mini controller/ 15974 install hiccup-14952320493931365525536.jpg   Nos mini controller/ 15974 install hiccup-149523213391010006038.jpg   Nos mini controller/ 15974 install hiccup-1495232195115775470427.jpg   Nos mini controller/ 15974 install hiccup-1495232234513458932023.jpg
Old May 22, 2017 | 09:50 AM
Are you sure the Fpss is working? If you followed the diagram and it's not getting power to the solenoids, I would bypass the fpss and see if it works. If it does, you might have to adjust the fpss(be sure this is seeing pressure while you're testing it)
Old May 23, 2017 | 01:14 PM
Default FPSS inpsection
I will ask to see if the FPSS is working correctly, I am not sure how it is installed on his vehicle.
Also, the Wht/BLu wire to controller, does it need a 12V voltage to activate the WOT switch in controller
Old May 24, 2017 | 03:17 PM
Default FPSS bypassed
We by passed the FPSS and just used the normal ground. When I get home I will check to see if it worked again.
Old May 24, 2017 | 06:50 PM
ragtopz28's Avatar
FPSS sucks, gave me fits. A new one didn't work either....They are all in the trash now. System works great.
Old May 24, 2017 | 07:18 PM
blk00ss's Avatar
Yup. Junk.
Old Jun 9, 2017 | 06:15 PM
Default ****solved*****
Got it connected correctly. 15974 mini needed a ground to blue/white wire.
Old Jun 11, 2017 | 02:18 PM
Default Diagram for my setup
All it needed was a ground input to the microswitch.Nos mini controller/ 15974 install hiccup-nosmini_with_wot_switch_and_purge_e718c2b5d7bea6c73a948eb10b7edb857e12e45b.jpg
After the burn out to warm the tires. He would stage his car.
When engaging the arming switch, providing 12v to Mini controller and pin 86 on relay connecting path of 12V from the battery to pin 30 to 87 to solenoids.
Mini controller is activated to allow programming to function with "r r" on LED display. Tach set at 2 seconds after WOT engaged.
The dry run was a success! We moved the vehicle out in to the street for safety reasons, Cranked motor to norm op temp. Went over safety plans. Opened the bottle up, purged to ensure enough was at the throttle body.
motor was at 2500 to 3000 RPM, WOT was engaged and 2 seconds later the engine increased as the nitrous and fuel mixture was being supplied RPM's inceased significantly. We were pleased. Now off the the track for testing.
Last edited by fathead7466; Jun 11, 2017 at 02:41 PM. Reason: description of test.
Old Jun 11, 2017 | 02:51 PM
Default video link
let me know if you see the video.
A special thanks to brandon from NitrousOutlet.com for the help.
Old Jun 12, 2017 | 08:34 AM
You're welcome! Glad you got it all sorted out.
