Questions on nitrous tuning vs N/A tuning
Thinking about a 150 wet shot for my 2000 Camaro. Car will mostly be n/a.
Instead of 2 separate tunes can I get away with a timing retard box or control box?
And what else should I get?
Or does it make sense to get hp tuners and run 2 separate tunes?
Obviously I'd get all your safety switches and purge kit, I'm mainly concerned about tuning and not blowing up the motor.
The LNC-2000 by Lingenfelter is perfect for what you're wanting to do. You can run the same NA tune you have now. When the nitrous is on, the LNC-2000 will retard the timing for you.
http://www.nitrousoutlet.com/electro...ontroller.html
So basically a good n/a tune on the dyno then get some data on how much to retard timing?
I run ethanol free 93 octane with stock ls1 compression. I'm sure I don't need but a couple degrees. But if I ran your standalone fuel system for the nitrous and put 108 in it I probably don't need any retard.
