Nitrous outlet fbody kit
Old Jan 2, 2018 | 09:18 PM
DarynSchultz's Avatar
Default Nitrous outlet fbody kit
Was curious about the nitrous outlet fbody kit and the plates they come with, my camaro came with a bbk 80mm TB when I bought it and the nitrous outlet kit comes with multiple sizes except that size, should I just swap back to the 78mm tb or will one of those plates work with the 80mm, is anybody running that kit if so how has it been holding up ?
Old Jan 2, 2018 | 10:21 PM
HCI2000SS's Avatar
Have a link to the kit you're talking about?
Old Jan 3, 2018 | 02:45 PM
https://www.summitracing.com/parts/n...SABEgJ47_D_BwE
Old Jan 3, 2018 | 02:47 PM
The other kit comes with 78mm TB
Old Jan 3, 2018 | 03:15 PM
HCI2000SS's Avatar
From my understanding a 78 plate should work on the 80 if it has the same 3 bolt design, however youd have like a 1mm step down where the plate meets the TB. You probably should contact Nitrous Outlet to be sure though
Old Jan 3, 2018 | 03:58 PM
brandon@nitrousoutlet's Avatar
Hello Daryn,
Our 78mm plate system will work with your BBK Throttle body. As said above, there will be a 1mm step around where the throttle body meets the plate. Feel free to give us a call if you have any questions!
Thank you,
Old Jan 3, 2018 | 06:20 PM
thank yawl both for the information!
Old Jan 4, 2018 | 08:22 PM
5.7stroker's Avatar
If you are running a stock intake and have plans to upgrade the intake and TB in the future to something like a FAST 92 and NW 92, it may be best to get the 92mm plate kit instead. If you plan on staying with the stock intake, then the 78mm will be just fine.
