Safe cam grind for nitrous
Old May 2, 2018 | 07:45 AM
Lsnewbee's Avatar
Default Safe cam grind for nitrous
Im trying to figure out if my cam would be safe to handle a wet shot up to 100-150 max specs are
246-250 627 630 112+3. Wont be sprayed alot.
Old May 2, 2018 | 04:21 PM
HCI2000SS's Avatar
Why wouldn't it be safe?
Old May 2, 2018 | 04:55 PM
Lsnewbee's Avatar
Some cams aren't ment to run on the juice . Just figured I better be safe then sorry and ask.
Old May 2, 2018 | 04:56 PM
Lsnewbee's Avatar
Some cams aren't ment to run on the juice. And i dont know a whole lot about it.Just figured I better be safe then sorry and ask.
Old May 2, 2018 | 04:58 PM
HCI2000SS's Avatar
That's really only when you start getting into larger shots. On a 100-150 it's not an issue
Old May 2, 2018 | 05:02 PM
Lsnewbee's Avatar
Ok thank you for the reply i wasnt sure of that so thats why i asked
Old May 2, 2018 | 05:05 PM
HCI2000SS's Avatar
Yep it's always good to ask. What's the rest of the build look like, and what vehicle?
Old May 6, 2018 | 09:08 AM
pantera_efi's Avatar
Default OverLap with NOS 116+
Hi LS-B, I would be more concerned about the Tune, how much Spark Retard with NOS ?
True, cam specs are safe. (250 Ex)
Lance
Old May 6, 2018 | 10:41 AM
Lsnewbee's Avatar
Lance
I bought a kit from a member off here last year it has the timing box. Do i need to worry about my spark plugs on a small shot im thinking 100 max and it wont get sprayed much just a few times at track and some street use at times
Old May 8, 2018 | 05:21 PM
allblackedout5's Avatar
Have to verify through tuning but I'd still go down to a 6 or 7 range plug at 100 shot depending on how your motor is reacting to the spark and octane on spray.
