There's one thing that most here probably know but haven't yet mentioned for this instance.. I am only guessing on this but I am under the impression from your post that you're assuming that pulling timing is killing power, so you'd rather spend $70 on 5 gallons of fuel. Well, without Nitrous yes that would be true, however, pulling the appropriate amount of timing while spraying may actually benefit rather than hurt your power output. IF you're detonating or your computer is pulling timing for knock retard, then you're actually losing out on power, while say you spray the 100 shot on 93 octane fuel with a few degrees pulled you may actually make more power and do better than your 100 shot on c16 with no timing pulled. I hope this makes some sense to all, in my head it does but sometimes I do not articulate my thoughts well. In short can you do what you're asking, certainly... Is it smart or the best practice here? Eh not really... just pull a little timing and stay with 93 and get a colder plug in there. I do not know what you're running now but I'd say a 6 or 7 range would be appropriate at 100 hp wet shot on a stock-ish motor. Nitrous tuning is very situational, and you can get away with living on the edge, for a little while anyways but when it lets go, boy it really lets go. I will say this also, just so you know, in the world of Nitrous 50-100hp is NOTHING for spray.
