200 Wet Shot on stock bottom end LS2
I have an LS2 vette with just over 12k miles. I’m going to run Nitrous but I was wondering if the stock bottom end can handle a 200 shot. My tuner is very good and builds a lot of high end Nitrous motors so I know it will be spot on. Here is what I have done:
-Corsa Xtreme Exhaust
-LG 1 3/4 Headers
-LG X-pipe
-NGK BR7EF Spark Plugs
-MSD 8.5mm Plug Wire Set
-Vanaram Cold Air Intake
-BTR Double .660 springs
-BTR Titanium retainers
-BTR Chromoly pushrods
-LS7 Lifters
-Straub Technologies Trunion kit
-BES Stage CNC 243 Heads
-ARP studs and fasteners
-Tick Polluter Camshaft
-Lingenfelter C5R Timing Chain
-Fast LSXR 102 Intake
-Fast Fuel Rails
-Walbro 450 Fuel Pump
-Skunk 2 Mechanical Fuel Pressure Gauge
-Nick Williams 102 Throttle-body
-Deatsch 42 lb injectors
-Nitrous Outlet Fast 102 plate kit
-Nitrous Outlet Window Switch
-Nitrous Outlet Purge Kit
-Nitrous Outlet Bottle Heater
-Nitrous Outlet Filter
-Nitrous Outlet blowdown tube
-Custom Nitrous Switch panel
-Lingenfelter Timing Launch Control LC2000 Box
-SLP Under-drive 25% Pulley with ARP bolt
-ASP Over-Drive Alternator Pulley
-160 Degree Thermostat
-Comp Cams Rocker Trunion kit
-Comp Cams Billet Idle Tensioner and Pulley
-McLeod RST Clutch
-McLeod LS Flywheel
-Tick Clutch Master Cylinder
-AEM Electronic Fuel Pressure Gauge
-AEM Wideband Air/Fuel Ratio Gauge
-ECS Rear Differential Brace
I really only plan to use the Nitrous every now and then so I’m not opposed to dropping it to 150 either.
-LG 1 3/4 Headers
-LG X-pipe
-LS7 Lifters
-Fast Fuel Rails
-McLeod RST Clutch
-McLeod LS Flywheel
The LS engine can handle up to about 700HP. You should be OK.
