Timing Tuner Works ok Now
Old Jul 13, 2004 | 10:57 PM
Pro Mouse's Avatar
Angry Timing Tuner Works ok Now
Well I tried auto tapping my timing tuner tonight,ran 2 runs with out the n2o activated,to make sure of where my timing is,Then flipped the switch with the bottle off had it set for 5 degrees of retard on the RTD switch both Base and WOT timing are at 0.Guess what my timing was the same!Boy I sure am glad I didnt just run the nitrous.So what did I do wrong?The check lights are working right.So why didnt it pull timing out?
tia
Old Jul 13, 2004 | 11:19 PM
kp's Avatar
kp
The timing wont show being changed using auto tap or any kind of scanner, put it at 15 degrees retard and activate it - if its working you will feel it.
Old Jul 14, 2004 | 01:07 AM
Hawkn01's Avatar
The timing tuner alters the signal after the PCM, so it won't show up on ATAP.
Old Jul 14, 2004 | 03:30 AM
Pro Mouse's Avatar
No Kidding,You guys are serius?I just tought that would be the way to check it.I am sure if I retard it that much I will feel it,I hope?I will give it a try....Thanks
Old Jul 14, 2004 | 06:45 AM
jamnut's Avatar
The timing tuner pulls timing while fooling the stock PCM into thinking it's still got full control of timing.
Only if you pull timing by programming will you see it on ATAP.
Old Jul 14, 2004 | 08:38 AM
kp's Avatar
kp
Actually it alters the signal before the PCM, if it altered the timing after the the PCM it would have to be hooked to the coils
Old Jul 14, 2004 | 08:51 AM
marlowchris's Avatar
So which is it, before or after the PCM?
Old Jul 14, 2004 | 08:54 AM
TigerFan187's Avatar
Is the timing tuner activated whenyou utrn your system on or is it activated at WOT and if neither when and how is it activated?
Old Jul 14, 2004 | 09:15 AM
kp's Avatar
kp
Its before, since it the crank sensor is before the PCM (thats where its hooked to) it obviously isnt after the PCM. It alters the signal from the crank sensor, the PCM doesnt 'know' anything is being altered therefore the timing according to a scanner wont be changed. Right from the manual:
The unit installs ‘in-line’ with the crankshaft
sensor wiring and alters the signal that is received by the PCM (Powertrain
Control Module, ‘engine computer’). By shifting the crankshaft signal
ahead or behind in time the spark timing in the engine is changed.
Since its also a window switch its hooked to the nitrous relay and thats what activates it.
Old Jul 14, 2004 | 12:17 PM
383LQ4SS's Avatar
Yes..its before. And it will not show up on a scan tool. But it does work.
Old Jul 14, 2004 | 02:08 PM
SDB's Avatar
SDB
tia
You need to not post topic sentences like "Timing Tuner works for ****"...when you don't know what your talking about. Your essentially bashing a product that you don't understand and may not have hooked right. You may give some poeple who are looking at using this tool a misconception. If you need help with these things, there are pleanty of forum members to help. I have the timing tuner and it works fine. Nitrous is a great way to go fast, but with all the electronic stuff we need it can be frustrating! But when you post topic like this it can be misleading to others...
Old Jul 14, 2004 | 04:04 PM
Pro Mouse's Avatar
Thumbs up
SDB You are correct,I dont know anything about this thing and I am not trying to mislead people,But I do know it works now because my tuner mistakenly put my n2o tune back in the car and it was kind of a dog.I put it 5 deg adv and WHAHoo ,It woke it right up!I do know it works.When I made the false n2o run it didnt show up on my A-Tap so I thought it wasnt working when it was.But Thanks to you SDB and Marlowchris it does work,otherwise I would still be trying to figure out what the nitrous relay is
Scott
Old Jul 14, 2004 | 07:15 PM
dlandsvZ28's Avatar
Pro Mouse
If the Timing Tuner works now as it was intended then you should edit your subject line to something more appropriate.
Old Jul 14, 2004 | 07:19 PM
Pro Mouse's Avatar
Better?
