Nitrous Bottle Warmer
Old Apr 5, 2022 | 02:08 PM
98cherrySS's Avatar
Default Nitrous Bottle Warmer
I have the nitrous bottle warmer/mount from Nitrous Outlet (as well as a bottle blanket) and it takes a good 25 minutes to bring the bottle up to temp. Is there a better way to heat the bottle so it comes up to temp sooner?
Old Apr 5, 2022 | 03:04 PM
MaroonMonsterLS1's Avatar
are you sure you don't have a wiring issue or a control issue?
We use a warmer blanket and a milwaukee 12v battery on our race car and we can have a bottle up to temp in the lanes in a matter of minutes
Old Apr 5, 2022 | 05:12 PM
RedXray's Avatar
I've read the bottle bracket with the integrated heater is a little slower than the regular wrap around heater as it has less surface touching the bottle. I ran a 10 gauge wire with a connector used for boat trolling motors to the heater for quick disconnect.
The heater is the cheap Dracary $75 from Amazon and it works surprisingly well. The bottles are mounted in the bed of my truck out of direct sunlight hidden under a Bakflip Tonneau cover. Summertime the bottles heat up fast and the transducer cycles very little... and of coarse with colder weather it takes a bit longer.
Old Apr 6, 2022 | 07:34 AM
98cherrySS's Avatar
I don't think it's a wiring issue. Voltage is constant. I have it on a relay with 10ga wiring as well. I think the heating element in the bottle bracket only contacts 1/4 of the bottle vs the wrap style which probably heats all sides of the bottle. Eventually it'll reach temp/press. It's just super slow. Thanks for sharing the Dracary option. I may give that a whirl in place of the bottle bracket.
Old Apr 15, 2022 | 09:48 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Bottle warming is fast vs safe. I have seen more people than I can count pull out propane or mapp gas torches to heat a bottle. Works real fast, but do you think that is safe? Best is up to you.
Old Dec 7, 2022 | 11:38 AM
LilJayV10's Avatar
The integrated bottle heaters do not heat the bottle up as fast. As you mentioned there is very little surface area compared to the wrap style.
They are convenient and look nice, but don't do as good of job.
Old Dec 14, 2022 | 03:41 PM
Forcefed86's Avatar
Get yourself a propeller heater. Or an electric "DE-ICE BOOT" that they use on aircraft. The 24v versions with a tool bat work REALLY well. Even at 12-14v they were cheaper, hotter, and worked faster than the N20 bottle blankets I worked with.
https://www.ebay.com/itm/173953234509
