Nitrous/ quarter mile
N20 is super simple. If the car runs well without it, and falls on its face when activated... the N20 is likely not flowing. You need to test and verify it is. If N20 and Fuel are spraying… then what ever you are using to retard timing is wired incorrectly or not setup right. Disconnect the fuel and N20 and test the kit’s timing retard device on its own in that case.
Lastly, your intake may be less than ideal, but has nothing to do with the nitrous not working well. A btr stg 3 will pull WELL past 6200 on a 5.3. What are the cam card specs? You should rev that combo out to 7000++ IMO. In general, the higher you rev it and the longer you wait to spray the better.
Sounds like you may need another tuner... Also if you "Test" the N20 with the engine not running be sure not to try and fire the engine with the manifold full of nitrous. Give it time to disperse.
What intake is on the car? 102mm is the TB diameter. Once its open, its open. The less restriction there the better. A 102mm TB isn’t going to cause issues with WOT performance… or your power adder. Only drivability… esp if it’s a cheap/poorly made TB. If you have a short runner cheapy intake, this will cause the performance below 5500-6000 to drop well below what a factory intake manifold would be, BUT it will still make great power once you smack it with 150 shot. It WILL NOT cause it to “spit and sputter”.
Poor NA performance can be due to several things… converter slip, vehicle weight, poor 60’ and 330’ times etc… What it your 60’ time? What does it weigh? What is the trap speed?
IMO, your limiter is set WAY too low for any factory small bore LS. Bump the limiter to 7500. Try shifting at 6800, 7000, 7300. And see if it picks up a ton. You need to remember there is likely a "soft limiter" generally set about 200 lower than the hard limit. I've seen 500 rpm soft limiters... So if your set at 6200 for the hard limit... it may start the soft limit as low as 5700. Also when it "spits and sputters" what is the RPM doing? Could it be blowing through the converter and hitting the limiter? What does the converter stall to? brand and specs etc?
I'd get it ironed out NA first. Then address the N20 issue.
What brand/model is the intake manifold? Are you saying it’s an LSX FAST 102MM intake? If so, there is zero reason to change that. And if the tuner is telling that or the cam will cause spitting/sputtering with nitrous activation.. Don’t use that “tuner”. The FAST 102 works almost as well a factory down low and makes decent gains up top.
Plug gap can certainly be an issue. That’s quick and easy to trouble shoot. Gap them at .015 and try it. If that solves your issue, bump them up .005 at a time until spark starts to blow out again. I generally gap small and don’t worry about the few HP lost in doing so.
I understand the converter may be advertised at 3800. But if you stab the throttle from a stop does it actually stall to 3800? If so that should work well. But I doubt it does.
A 2.2 60’ is pretty bad. Do you run a drag radial tire? If not I’d start there. Leaving a half second or more on the table with a 2.2 60’. For every tenth you knock off the 60’, you gain 2 tenths in the ¼ ET.
Post your slip. Really MPH and weight will tell you power, not ET. Try to weigh the truck with you in it and a full tank sometime. At the track, truck station, dump etc… What is it trapping? Trucks are VERY heavy. 2000 single cab is listed at 3900-4400lb curb weight. Then add the driver weight. That’s a TON of weight to move. I also wonder about the gear choice. With such a low limiter are you able to finish the ¼ in 3rd without going into overdrive?
That cam will pull to 7k with good springs and a 150 shot no problem. It may not peak power wise over 6500, but it will carry the power fine. I’d stay away from the tuner for now. Try the plug gap, and work with what you have instead of throwing expensive parts/labor at It right away.
2800rpm isn’t enough to launch “hard”. Luckily you have 150 shot to offset that down the road once everything is ironed out. The intake and cam will easily get you into the 13s with a good tire and more power off the line.
The Fast 102 and TBSS or prior truck intake manifolds all performed very similar up to 6k. The Fast makes a decent amount more above. No reason to change that IMO. Down the road I’d want a larger cam and looser converter. But I’d get it working correctly first with that you have. I’m sure it has quite a bit more in it “as is”. Throwing parts at is when its not running right isn’t going to change much. The combo you have will run much better, something is “off”.
90mph @ 4500lbs puts you at 253 HP. That’s about 100hp off where you should be I’d guess. You may be heavier than that, but it still seems down on power.
What ECU is in the car? Id go back the basics. Do a compression test. Get a timing light and make sure the timing is sync’d properly to the ECU. I just built a car that was WAY down on power. Come to find the timing was off 12* between actual timing and what the ECU displayed. If your tuner doesn’t have a dyno, might look for one that does. Much easier to see what’s going on.
2.2 60’ is bad for a drag radial. For reference my 275 street tires would routinely pull 1.9 60’s in a 3500lb gbody. That alone would get you into the 13s. You should be closer to the 1.6 range with a good set of drag radials and decent suspension.
E85 will be slightly harder to light off, but shouldn’t be a major issue. Again, just gap plugs at .015 to eliminate the possibility of blowing the spark out. You can always add gap back once the combo is ironed out.
Once you figure out the missing power issue NA. You shouldn’t have to pull timing with a 150 shot on E85. Most don’t. I’d try a 50 shot and eliminate the “timing retard” device. See if your Sputter goes away. Work your way up to 150 watching the plugs.
What kind of power did it make on his dyno? What kind of timing? Even if that setup isn’t “perfect”. It *should* make every bit of 400crank HP NA. If it doesn’t, its not the parts IMO.
