NXL fuel solenoid problem?
Old Jul 23, 2004 | 10:00 PM
Greg Fell's Avatar
Default NXL fuel solenoid problem?
I dyno'd my car today, and it is extremely lean. I unhooked one of the fuel hoses on each rail, and manually jumped the solenoids. The nitrous solenoids open with a very loud click. The fuel solenoids are audible, but not nearly as noisy. Also, with the car fuel system pressurized, NO FUEL comes out!?
Does this sound like 2 bad fuel noids? I would expect fuel to shoot out of the rail with the key in on position (not running), right? Help please.
Old Jul 23, 2004 | 10:17 PM
MeanWS6's Avatar
NX noids are pretty quiet, but yea with the key in the "ON" postion I think you would have fuel shoot out of the rail - that makes sense.
have you checked your fuel pump fuse, (just a shot in the dark)
What jets are you using? For the 180 shot, I tried the 28/14 and was pig rich, then went to 28/12 and was too lean.
THe NXL kit is a bitch to tune, that is why I am going back to a more simple setup like the maf kit
Old Jul 23, 2004 | 10:21 PM
MeanWS6's Avatar
Im gonna run outside and do the same test and let you know, be right back . . .
EDIT: I did the same test, could barely hear the noids come on. Pulled the Fuel lines off of the rail and turned to "ON" postion - nothing.
Tried on two on each side for ya, front and back of the rails
now, this leads me to think its the same jetting issue that me and everyone else has been running into
Old Jul 24, 2004 | 05:07 AM
CAT3's Avatar
Restricted User
You are not the only one with that problem. If you call Nitro Dave, he might be able to give you the name of the tech guy at NX. Call the tech and expalin whats up, send the rails in and they will replace the solenoids.
Good luck.
Old Jul 24, 2004 | 08:37 AM
Brains's Avatar
Yup, mine are doing the same thing. I pulled the solenoids out and installed a thicker O-ring, which helped but I'm still not convinced its spraying the full volume. I'll be calling and talk with the NX guys on Monday, see what they say.
Old Jul 24, 2004 | 10:34 AM
Greg Fell's Avatar
Awesome! At least I know I'm not the only one. Thanks for the help fellers.
Old Jul 24, 2004 | 02:46 PM
93LS1RX7's Avatar
Mine make a VERY loud click. I may try this out and call NX on Monday
Old Jul 24, 2004 | 02:51 PM
JF WS6's Avatar
Well, you guys got my attention. I'm very curious to see if this is a universal problem or just a few exceptions.
I haven't been able to run my system yet since I installed it at the beginning of the year cause I'm still waiting for Jay at Absolute to get my heads back.
At least this is hopeful in the relevance of everyone seemingly having problems getting their systems running and tuned properly.
Old Jul 24, 2004 | 04:59 PM
marlowchris's Avatar
My system is not flowing the full amount of fuel either. I attributed this to having too small of fuel pills. But maybe the solenoids are not flowing the full amount. It would be diffuclt to check this without the proper tools though. I am going to try larger fuel jets. Let us know what you find out. I do know that NX is redesigning the solenoids to allow for better fuel flow to support above 180 shot. This system does seem problematic.
Old Jul 24, 2004 | 08:08 PM
MeanWS6's Avatar
does anyone have connections over at NX with Ricky the designer. I think they need this post (as well as the hundred other ones( regarding too rich/too lean needs to be brought to their attention
If no one volunteers, I will do it late next week when I get back.
THis is getting out of control the amount of problems these kits are giving all of us
Old Jul 25, 2004 | 02:25 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Are you guys trying the test with a cold engine? Just wondering if the solenoids are getting to hot...Sounds like NX needs to know about this. Im sure they will come up with a fix for you all. Sticking fuel solenoids or low flowing is scary stuff! Any of you folks datalogging this problem to see how lean it really is?
Dan
Old Jul 25, 2004 | 02:52 PM
Greg Fell's Avatar
Have not tested with a cold engine. I will go try that in a bit. I have wideband a/f results and atap results, and yes its VERY lean.
Old Jul 25, 2004 | 03:33 PM
MeanWS6's Avatar
Greg - I tested on a cold engine.
What jet combo's are you running?
Old Jul 25, 2004 | 04:01 PM
gvzo6's Avatar
I am going to check fuel sol with car running and rails pressurized
Old Jul 25, 2004 | 04:57 PM
gvzo6's Avatar
sol are opening ,every nozzel is getting fuel
Old Jul 25, 2004 | 08:53 PM
Greg Fell's Avatar
I am running the 120 pills. My fuel noids do not work correctly. Only the faintest noise.
Old Jul 26, 2004 | 10:13 AM
Greg Fell's Avatar
I spoke with Josh @ NX, he is sending new pistons because he thinks they have swollen up due to something in the fuel. I use 93 from Amaco exclusively. I am concerned this will happen again. I never had any problems with my TNT noids sticking. I am a bit uneasy about this fix. I am sure it will fix it short term, but I dont want the damn things to swell up and I spray no fuel.
How many other people have this problem?
Old Jul 26, 2004 | 10:36 AM
Fast94bird's Avatar
Fuel piston swell difenitly could be a problem. Also the additives the gasoline companies put into the fuels change from month to month. It is impossible to have one pistion work with all different types of fuels. IF this is the problem probabily will not happen again. Let us know if that was the fix.
Old Jul 26, 2004 | 11:56 AM
93LS1RX7's Avatar
I had one fuel noid fail completely and I am not sure with my results if the noids on the car are working correctly. Honestly I am beginning to get a little worried to even try it out because all the problems. I dont want to go big time lean and detonate the engine into little pieces.
Old Jul 26, 2004 | 11:59 AM
Greg Fell's Avatar
I am so nervous with this kit, I know fuel additives can cause the stopper to swell, but my TNT kit and all my friends TNT kits around here never have this problem....
