All NXL owners inside please . . .
Well, I have had it
I think, and many of you mentioned this before, that NX needs to know about this kit and the problems we are having. If you all want to post your problems or PM them to me, along with your contact information (name, addy, email, etc) and I will write an open letter to NX asking to 1) fix the lean/rich jetting issues within 30 days or 2) recall the LS1 NXL kit and provide us with a replacment nitrous kit of our choice (reasonably) such as the MAF kit or nozzle kit.
Maybe a sponsor or admin can help, or I will do it myself for all of us. This thread is NOT a NX bashing post and I will delete it if it turns into one. I will not take it as far as a lawsuit 'cause thats not my intentions. I like NX, I like the kit (or did) but just want it to perform as advertised without running too rich/lean, without having to buy yet more parts (such as the accumulator), and with 1/4 times that make sense with the kit.
I dont know, they may tell us to buff our nuts or actually try to help. Its worth a shot. I already have a few local guys that want to be included.
What do you all say, lets get these problems fixed, let NX make us happy customers or replace these kits with a different NX kit. I just want the final outcome for NX to be happy and NX customers to be happy.
So post or pm your problems (ie running too rich/lean, installation issues, fuel supply issues, low HP ratings, etc)
Again, I am not one to complain and usually roll with the punches when it comes to modding my car, but seems like every kit has the same/similar problems. This thread is to post your problems, or positive experiences with the kit. PLEASE dont turn it into a bash NX thread, lets keep it to the topic.
I am also open to suggestions, even if you want to tell me that I am out of line for suggesting this
glad to hear they are redesigning it, do you know how much MORE this is going to cost us or how long we will have to wait? Are they aware of just how wide spread the issues are?
I imagine that the 8-port distro block $$$? Where can I get my hands on one and what is the cost? I would like to finish the season knowing that 2005 will be nitrous problem free.
again, thank you for responding Brains!!! Didn't know they were working on a redesign.
Based on what I've read over the past year of the issues I've heard about, Brains suggestion seems like a good one. It would basically turn the kit into a NX version of NOS's NOSZLE kit, which has proven to be a very good performer. You'd also have the benefit of perhaps running a seperate fuel system if you'd like rather than running off the rails.
Brains, do you know specifically what they are trying to re-engineer with the kit? Are they designing new integrated solenoids? If they are re-engineering the kit, where does that leave all the rest of us that have the old design?
NX, if you are out there, make this situation right, please!
The rails should have been made with flared cups like the stock rails. That way the stock clips would have worked and you could install the injectors in them without shredding orings.
Again I havent dyno'd but those are my on track results.
BTW you may want to also send the letter to Nitro Dave. He is EXCELLENT at fighting for the customer and will bend over backwards to make things right. Well if that is where you bought your kit, it is where I bought mine. If you didnt buy your kit there then nevermind.
How can you tell if the solenoid is not flowing enough gas? How would you convert to a traditional 8 port distribution block and solenoids? I believe this woud involve removing the integrated solenoids and plug the holes, if possible. Then plumb lines directly from the block to each nozzle. If you did that then you do not need the NXL fuel rails or accumulator at all. Interesting idea though.
I did buy my kit from NitroDave. He will probably chime in here soon and he is aware of my problems. He told me that NX is redesigning the solenoids to flow better to support a larger shot.
And on the fuel rail rising up. I had the same problem abouta week ago. The bolts that secure the NX fuel rail brackets to the intake vibrated loose. The rail then rose up and the back injector popped out spraying fuel all over the intake & headers. Not good. I made my own brackets and used loctite on the bolts. So check your bolts guys before you have this problem.
Here are some additional NXL design problems:
1) The driver side fuel rail hits the firewall.
2) I installed the accumulator on the rear pass side fuel rail. I had to use a tight radius elbow instead of the supplied 180 degree fitting.
3) The fuel rail bracket issue addresses above.
4) The fuel rails should have been radiused where the injectos pop in. This would make installation easier and prevent damaging O-rings.
I spent a lot of money on this kit and NX should fix their mistake. Otherwise this is simply false advertising and means for a lawsuit, if you wanted to take it that far.
On the other side I like the way the kit looks, and hope that the fuel pump and jetting will fix my problems. Only time and more money will tell.
Chris
Same thing happened here!!!!
Speed Inc had to custom fab brackets to hold it in place. When I picked it up after the install - I drove the car home, stopped for about 15-20 mins, then ran down the the gas station, then about 2 blocks from my house on the way back I could smell fuel, pulled over and it was leaking fuel again. Called my neighbor and we pushed the car back to my garage. $75 towbill back to Speed Inc. I was LUCKY!!!
Now on the Jetting issue.Yes They are aware there is a jetting problem.We have offered the smaller fuel jets to lean out the system.
I talked to Ricky at NX today about the problems.Here is the solution that he has came up with. They are having another set of NXL rails machined for testing as we speak.It will be exactly like the ones you have.They will be putting the system on the test car.They will test the car on street and dyno.If there is any problem with jets they will send you the new tune up for free.If there is a fuel flow problem NX will supply the needed fix.All of there dyno runs will be posted.
NX is not hiding from any problems that might be.They want to make sure that if there is a problem that it is taken care of.GUYS THIS IS GOING TO TAKE TO 6 TO 8 WEEKS.
There has been 63 of these systems sold.But not that many complants.There are a few problems that I have seen,that are small problems.The biggest thing seems to be the jet pattern is off.
Please start a post in a thread with your name and what problems you are having.Please keep the clutter out.If you have not tested your system please do not post.I need to keep it simple so I can make a pin point on what problems need to be addressed.
Keep in mind that I am not NX however I have a very good relationship with the guys there and I beleive a 100% in them.If there is a problem they will address it and fix it.
Thanks
Dave
Why machine a whole new kit take one off the shelf from your shop dave so we dont get a ringer kit that they made sure was 100000% correct not what the rest of us have.
My other big heartburn is related to the tuning. Once they get the lean/rich condition figured out how about they get us jets that give the correct RWHP. I dont want 75hp from a 120 shot I want 120.
