Anyone put their bottle on the trans tunnel?
I relocated my battery to the truck so I lost that nice spot where the speaker is for my bottle...
I don't want to put it where my t-tops go either...
So i'm thinking of putting it where the trans tunnel is... have the handle facing me... so I could open it from the drivers seat
Anyone done this? have pics on how you mounted the bottle? I have a 15lb bottle but worst case I can use a 10lber (I have one of those too)
Any special considerations since the bottle is so close to the driver? (NHRA or IHRA) I'll have a blow off tube vented outside the car...
Their have been several threads on this. You can put a 15lbs bottle on the hump no problem if you don't run back seats. I simply cut my stock NOS brackets to make it bolt to the hump no problem. Before you drill any holes in the tunnel reach under the drivers side of the carpet and pull the fuel pump harness off the tunnel (clipped on with little stick on style clips).
Links to pics.
http://nitrousfedmuscle.com/images/rear640.jpg
http://nitrousfedmuscle.com/images/bottle2.jpg
Links to pics.
Sweet thanks guys I guess I coulda used that search thingamajig but it's so confusing
I won't have to worry about pulling the carpet... no carpet in the car (just had a roll bar installed a lil while ago)
GM Muscle thanks for the pics
Honez that looks REALLY good , i bet passengers have alot of fun with it hehe
