Wiring Two step with Timing Tuner?
Old Aug 28, 2004 | 03:17 PM
Silver Slayer's Avatar
Default Wiring Two step with Timing Tuner?
Does anyone have a wiring diagram to wire the Harlan two step in with the Ramcharger's Timing Tuner?
I can't figure out how to wire in the two step to disable the nitrous, while still being able to have the timing tuner control the delay and RPM limits.
Any help is appreciated.
Thanks,
Kevin
Old Aug 28, 2004 | 04:19 PM
jamnut's Avatar
I've thought about this many times. If anyone knows how to figure it out, I sure would like to know also.
I don't know if it's possible.
The only thing that I can think of is have the 2 step set at a lower launch rpm than the timing tuner's window switch, but that would mean that you can't use the nitrous delay feature, you would be spraying outta the hole.
Old Aug 28, 2004 | 05:07 PM
BMN's Avatar
BMN
I got it figured. Let me think it over to make sure I'm correct and then draw it up in Autocad. Seems real easy rite now. I'll repost Sun or Mon nite when I get it drawn up.
Old Aug 28, 2004 | 06:32 PM
jamnut's Avatar
What I was thinking about was to rig up a switch to go between my Wot switch & the TT. You could probably even use a spare wot switch. Mount it up under the dash so that when the clutch is released the clutch pedal lever itself would hit it to close the connection & activate the TT in concert with the WOT switch on your TB. That would keep the TT from kicking in while on the 2 step with the clutch pedal depressed.
The second you release the clutch bam, the TT is activated, your foot should already be on the floor because you were on the 2 step & that would take care of everythign.
I hope you can understand it, it's making full sense in my head, but getting my thoughts down on paper is a different story. I'm sure that it could be done with micro switches & relay's too, but I think what I've come up with is simple & easy.
Old Aug 28, 2004 | 07:23 PM
algws6's Avatar
doesn't the TT kick on once the system is armed? if so just hook up the two step to the WOT switch with a relay. maybe harlan will jump in on this.
Old Aug 28, 2004 | 07:50 PM
BMN's Avatar
BMN
OK, got a question on the TT first. Goin over it on paper and need to know how do u reset the N2O delay on the TT? Turn it off then back on? If it does then every time the clutch was pushed it the delay would start over again if u had it switch power off and on with the clutch pedal position.
Old Aug 28, 2004 | 08:56 PM
algws6's Avatar
the n20 delay is a feture inside the box. it has three or four dip switches to set the delay.
Old Aug 28, 2004 | 11:20 PM
BMN's Avatar
BMN
Not how u set it, but reset the delay after u make your pass.
Old Aug 29, 2004 | 04:01 AM
The delay automatically resets after the RPMs drop below 3000
Old Aug 29, 2004 | 06:32 AM
jamnut's Avatar
Exactly, as long as your car doesn't drop below 3k rpm's while shifting it won't reset the delay.
Old Aug 29, 2004 | 06:34 AM
jamnut's Avatar
My TT is wired into my WOT switch not my arming switch.
Old Aug 29, 2004 | 09:44 AM
BMN's Avatar
BMN
OK, so the delay starts once u hit 3K then resets when drop below it?
Old Oct 21, 2004 | 07:38 AM
To The Top
Old Oct 22, 2004 | 08:37 AM
jamnut's Avatar
Nope the way the box works is that once your delay period is over when you go WOT, if you are at or above your lower window setting it will start spraying.
Old Oct 22, 2004 | 05:08 PM
BMN's Avatar
BMN
What resets the delay?
Old Jan 1, 2005 | 11:59 AM
'02SS's Avatar
the delaY resets when you drop BELOW 3000rpms.i know this is old but i would like to know this too.
Old Jan 1, 2005 | 02:11 PM
BMN's Avatar
BMN
OK, lol, forgot about this post. Went over it saw how lost I was even after I got the answers to the ?'s I asked. Guess I didn't read it well enough.
So my final answers are : When you go WOT the TT reads it and then starts the delay. If the delay time is less then the time it takes to get to 3K RPM, it will then wait untill you reach 3K. (hmmm, kinda dumb, u have to wait till 3K anyway) If the delay time is longer then it takes you to reach 3K, then good. By that time you will be at 3200 or 4200 or whatever. When you finish your run, you drop down to below 3K and the delay will reset itself and wait untill you hit WOT again to start its countdown.
Makes 100% perfect sense now(if I understood u guys rite). Now this is real easy. I'm goin to Hooters for lunch now. I will draw it up on a piece of paper over there and then redraw it on AutoCad to post it for ya's. Is post holidays and kinda busy so might take a day or two to redraw it.
Old Jan 1, 2005 | 03:23 PM
'02SS's Avatar
take your time.we all apreciate it.
Old Jan 1, 2005 | 04:33 PM
BMN's Avatar
BMN
Yup, got it figured. The only thing is that there are several ways to wire it up. What would be benificial for you guys is if someone had a scan or the wire directions for the TT and eithor posted it or emailed it to me. That way I know where they want/have you place the WOT switches, relays, and other stuf and in what order. Then I can draw it up so that you would not have to unhook all of it to rewire it up just to match what order I have it all placed in. I'll just show where to tap, split, or split and make it a lot easier for you folks.
Old Jan 1, 2005 | 05:47 PM
Tim 98z's Avatar
You dotn HAVE to wait till 3000RPM you can set your TT to spray at a lower RPM. Not recommended IMO.
