Hong long does it take to install TNT Wet kit?
Old Sep 2, 2004 | 09:16 AM
soslo's Avatar
Default Hong long does it take to install TNT Wet kit?
How long does it take to install everything...switches, remote opener, bottle heater, guages in the a-pillar, purge, mounting, etc?
I would like to spray a wet 150 shot (is TNT still the kit to beat?)...power ring probably, unless there are direct port kits that actualy work out there.
Old Sep 2, 2004 | 09:32 AM
Hawkcmc's Avatar
A good day of work should do it, Making it look clean and show quality is what takes a while. If you are doing a 150 shot the power ring is a good choice, Direct Port is kind of over kill for that type of shot.
CMC
Old Sep 2, 2004 | 05:04 PM
Turo's Avatar
i installed my kit with all the safety accssories and a bottle heater in 1 day. i didint install anygauges or remote opener though. i got the kit on a friday, installed it the next day, and on sunday i was making test runs
Old Sep 2, 2004 | 08:29 PM
Ben R's Avatar
It depends on how good you want everything to look. A good estimate would be between 8 - 12 hours.
Old Sep 2, 2004 | 09:25 PM
soslo's Avatar
thanks guys. do you think nitrous is worth it?
Old Sep 3, 2004 | 07:14 AM
Devilss02's Avatar
I think nitrous is worth it. Just think of the bang for the buck theory. No point intended with the bang.
Old Sep 3, 2004 | 09:25 AM
Hawkcmc's Avatar
I spent like 5 days at 5 or 6 hours a day because i was making it show quality, installing gauges, making a custom swith panel, painting things and so forth. Nitrous is definately worth it I would have it on top of everything even turbos or superchargers just for that little extra kick.
CMC
Old Sep 3, 2004 | 03:14 PM
OneMeanZ's Avatar
CMC
Do you have any pics?
Old Sep 7, 2004 | 09:44 PM
Slow TA's Avatar
A good weekend if you want it to look good or 1 hour if you need it that night. just make your freind hold the bottle in the passenger seat and run the line outside the window and under the hood and just wire up a push button
Old Sep 8, 2004 | 11:24 PM
Black02SS's Avatar
I agree with everyone else. If you know what you are doing you can do it in about 6 hours for the basics. Once you install one kit, the rest are pretty much the same to an extent.
