Building 402 for nitrous, do I want high or low compression?
Will only be spraying at the track (for the most part). Considering doing the SLP 402 motor, low compression is 9:1 and high compression is 11.3:1.
I have heard that nitrous loves low compression, but in the same thread someone posted that nitrous loves high compression
whats the verdict???
Actually low or high compression will work well with nitrous...but for a MAX effort nitrous motor, stick to somewhere in the 10.5:1-11.5:1 compression range...its alot easier to get away with no detonation on big units (300+) compared to 13:1 type setups...
thanks for the replys guys, i will stick with the high compression
next-yea, i scrapped the 427 in light of the new SLP 402 pkg . . much much much cheaper and just as good of a motor (for the most part)
I'm gonna stick to 12.5 to 1 on my new 408, and the direct port kit. I won't be running pump gas, high octane unleaded motion lotion only.
Get the higher compression motor, and be damn sure to either O ring it, or use Cometic gaskets if you plan to spray it.
I almost think its a secret people dont realize, to run lower compression and more nitrous...
Ive had a few hondas on my dyno with 8.5:1 compression with 250 shots on them...its unbelieveable...yes they gave up 20-30hp with the low compression, but now they are running 100 unleaded on 250 shots on 4cyls.....
Like I said before, it depends on your tuner.
It depends on how much torque/CI (IE: HP/CI, but normalized for RPM), and what kind of fuel.
Nitrous can cope with higher compression than forced induction setups because it doesnt add as much heat to the incoming charge and because there is negative parasitic loss. As such, it is less succeptable to detonation, but it is not immune.
The fact that you're running a 402 is a key piece of information, but in order to give an informed answer, you will need to divulge more about the torque curve. Which, of course means building it to see
