120 shot what gains at the track
Guys I have a NXL system on the car and I am running a 120shot. NX states that their 120 rating is RWHP so keeping that in mind what kind of ET gain should I be getting using a 120shot? The car runs around 12.0@115ish off the bottle what should it run on the bottle? Stock motor if that makes any difference.
Thanks
Mike
Thanks
Mike
Justin my MPH is close to yours but my et is worse and I am running a little bit bigger shot.
Well I am running a 4.10 gear in the car right now and I am shifting into OD at about the 1000ft how much could that be slowing me down? A tenth or 2? a few mph?
I ran (all in the same day), 11.45 @ 118.4 n/a best, with 125 jetting on the NX MAF kit ran 10.41 @ 130.24 best. 28 degrees of timing 12.5:1 a/f NA and 23 degrees of timing 11.5:1 a/f with the nitrous.
Last friday in the 96's s-10 I went 12.7@109 on 38 deg with 110oct. Then went to 36 degrees and hit it with 100 and went 11.33@121.6, then hit it with 100 of the line and ramped it to 150 within a 1/2 second and went 10.94@124.9 with 34 degrees of timing. Also had a 1.57 60ft on the last run no spin on 235/60's.
