ok lets get this straight
also is there any other safty device i should look into other than a WOT switch, window switch or did i nail it on the head?
If you go wet...you just need the wet kit and fuel pump.
I would use a window switch as well.
What makes people think a wet kit is dangerous? The fact that it hits harder? Something to keep in mind is the reason a dry kit hits soft is because the AF ratio isnt right (during the time that its soft). That's dangerous too.
My vote is for a wet kit and soem type of O2 monitoring to cut off the nitrous if it goes lean. One example of that is the NX maximizer, but it's a little expensive if thats all you use it for.
Steve
Another item I would strongly suggest is a tuner of some type - I have the LS1 Edit only because that is the only tuner out at the time. This way you can tune the car when ever you want. One program for engine only, one for each shot you want (I have 2 program for engine only, and 1 each for 100, 150, 200 and 250).
To get into the 10's and be consistent you'll need a good suspension set up.
Good luck
David
One solution is to use a fogger or direct port kit. A fogger is a direct port kit, but instead of piggy backing the stock injectors, you plumb nozzles into the manifold at each runner.
