gemini kit questions
Old Sep 23, 2004 | 02:53 AM
1dirtyZ's Avatar
Default gemini kit questions
whats the lowest horsepower setting this kit can produce ?
is there a way to get jets to run lower hp levels? higher ??
how does the inside of the maf look? is there a bar that runs accross or are they nozzles or what? (pics would be great)
this might sound dumb, but how even will the distribution of the n2o/fuel be in the air stream? ( biased to the left or right? top or bottom?)
finally , anyone have any pics of the inside of the maf ( discharge point) or can you atleast describe it.
Old Sep 23, 2004 | 08:31 AM
jermstyle's Avatar
I don’t have any pictures of this, but I can try to describe it for you.
The MAF kit replaces the MAF ends only. The bar that goes across the MAF assembly that supports the MAF sensor has two ports where the N20 and Fuel are injected into the air flow. The actual JETS are on the sides of the MAF ends where the feed lines connect from the solenoids.
The lowest jetting that comes with the kit is 35… If you’re only going to spray 35, are you sure you want to fork over the cash for the MAF unit?
However, you can expand the MAF unit to function as a dual stage, so you could run a 35 and then a 150 if you wanted.
Jeremy
Old Sep 23, 2004 | 08:35 AM
Nitro Dave's Nitrous Outlet's Avatar
Sorry I dont have a close up picture.The maff ends basically have a shark nozzle machined into the spray bar.It atomizes the fuel and nitrous well.
Dave
Old Sep 23, 2004 | 09:46 PM
1dirtyZ's Avatar
thanks for the information guys.
so ther is no bar going across the maf? (i.e. like a plate system on a carb) but instead its a nozzle, correct?
now where is the nozzle located? 12 o'clock position? 9,3? and where is the second nozzle located?
thanks in advance!
Old Sep 24, 2004 | 12:36 AM
jermstyle's Avatar
There is a bar that goes down the center of the MAF and both ports are in the center... The jets are on the sides of the maf ends inside the AN fitting.
Why so many questions? What are you thinking about?
Old Sep 24, 2004 | 11:45 AM
1dirtyZ's Avatar
thanks jermstyle, thats what i wanted to know.
sorry for bugging you guys about this, its just that the mixture on this application has to be perfect, i can't have it biased to one side or the other like when you put a nozzle on one side of a tube.
Old Sep 24, 2004 | 11:53 AM
Ill get a pic for you some time today.
Dave
Old Sep 24, 2004 | 12:17 PM
NicD's Avatar
7 Second Club
I would have to say the NX Maf kit is going to be your best bet. Both nozzles are located in the back center bar and spray directly in the center of the opening. You can look at mine sometime if you want. Oh yea, you will also want to skew your MAF table very very slightly since the NX Maf ends are very slightly larger than stock. Easily done though.
Old Sep 24, 2004 | 09:48 PM
1dirtyZ's Avatar
cool thaks for the help guys.
nic, i might take you on that offer
