Maf Vs. Direct Port
Old Oct 11, 2004 | 12:45 PM
99Ws6TransAm's Avatar
Default Maf Vs. Direct Port
Which is more sufficient? Running on a 99 bolt on only car. Looking to do a 150 shot.
Old Oct 11, 2004 | 01:48 PM
hellbents10's Avatar
LS1Tech Sponsor
150 I would go MAF. If you want to go any higher in the future like 200+ I would go DP.
Old Oct 11, 2004 | 02:02 PM
jermstyle's Avatar
MAF kit will do fine even for a 200 shot.
I'm running 150 on mine with no probs at all.
Old Oct 11, 2004 | 03:21 PM
MeanWS6's Avatar
Go with the NX MAF kit for up to 200 (possibly 250), anything larger you will need DP. With DP systems, their is ALOT more tuning issues. MAF kits are more "set it and forget it"
Old Oct 12, 2004 | 08:49 PM
GueSS Who's Avatar
I am spraying 300 shot through my maf.
408 CI
300 NX Maf kit
710rwhp/870rwtq
6.05@115 in the 1/8 mile
Old Oct 13, 2004 | 12:56 AM
toxic99's Avatar
MAF kit more than good enough for you. Cheaper too.
Old Oct 14, 2004 | 12:48 AM
HouseWS6's Avatar
what would it take to spray 200 through this MAF kit, just jetting? Id assume I'd need some more tuning but what about the fuel system on these cars?
Old Oct 14, 2004 | 01:20 AM
jermstyle's Avatar
Fuel system upgrades should be done for any nitrous/forced induction setups.
The NX MAF kit comes with jets for 100,150,200 & 250, so it's just a matter of swapping them out. You will need a good tune for anymore than 150 (direct port or MAF), tuning is a good idea in any case though.
Old Oct 14, 2004 | 01:28 AM
HouseWS6's Avatar
would a better fuel pump and some 30lb. injectors with a tune be good enough for a 200 shot? also, which pump would you recommend? Thanks
Old Oct 14, 2004 | 07:24 AM
jermstyle's Avatar
I have the Racetronix fuel pump/harness www.racetrnoix.com
You should read about this system, it's really nice. This pump will feed the need up to 700 HP.
You're stock injectors are fine if you go with a wet kit because you are injecting fuel and nitrous. With this fuel pump and a tune you can spray 200 just fine.
Old Oct 14, 2004 | 02:56 PM
HouseWS6's Avatar
link didnt work, but I figured it out..Thanks again..
Old Oct 14, 2004 | 03:41 PM
jermstyle's Avatar
http://www.racetronix.com/
Sorry, I should have checked it! Thunder Racing sells this system for the best price I've found and they ship fast!
http://www.thunderracing.com/catalog...vid=3&pcid=166
Old Oct 14, 2004 | 05:39 PM
HouseWS6's Avatar
SO how easy is the install of this pump, I see its PNP for the 98's, never even looked to see what would be involved in a swap.. Cheap too..
Old Oct 14, 2004 | 07:05 PM
jermstyle's Avatar
Hmm, you have a 98? The steel tanks are a bit harder to deal with I hear. Mine is a 02 with a plastic tank so it only took a few hours to complete.
There are instructions floating around if you search the forum for racetronix install and racetronix also has very detailed instructions they will send you if you email them.
Its a very nice system though, and the best part is that he goes in the tank and is quiet. Mine really doesnt sound any louder than stock, unlike some of the inline pumps that sound like junk.
