got flamed today about nitrous
I agree the parts should be between $200 and $400.
I've never paid more than that to put nitrous on any of my cars.
That old nitrous system is no longer in service. The next system will be a direct port with a purge, dual bottles with remote openers and heaters, a stand alone fuel system, a progressive controller and almost all the bells and whistles. I figure this one is gunna cost in the higher $2,xxx range after its all said and done and thats doing all installation myself.
Josh S.
Purges: Clean out the lines to ensure a good shot of nitrous everytime
Means: More consistant and reliable power
Bottle Heater: Pressurizes the nitrous bottle. In case you dont know, nitrous kits dont come with pumps, it is forced into the intake through bottle pressure, the heater creates a nice consistant pressure and you nitrous works better. Also if your not using one, when you get low on nitrous you wont see those big gains anymore.
Means: More consistant and reliable power, nitrous also lasts a bit longer
Window Switch: Well im a bigger fan of the timing tuner which costs a bit more. But it is a bit more safe and will allow you to do a wet 150-shot and not have to worry about it. The timing tuner engages the nitrous at WOT and a certain RPM and it disengages it at a certain RPM, but if your running a 150 shot on stock motor, it also allows you to pull a few degrees of timing when the nitrous is on, and then puts it back when the nitrous is off. Lets you keep your N/A power and get the nitro power, safely.
Means: Again, reliable, safe, and allows for using more nitrous, bigger shot
Bottle Opener: Well this isnt as much of a must, unless your a street racer. Dont want the fuzz to see your bottle mounted between the seats. And again if you dont know, your not supposed to mount the bottle sideways in a car. Its supposed to go the same direction your travel. Keeps the nitrous from tumbling at throttle in the tank and not coming out as easily. So the spare tire spot is a good mounting spot and then you need a bottle opener if you run into a good race.
Means: Pretty much a must for street racing, where you never know who you'll run into.
All these thinga cost you a bit more than 300.00. Off the top of my head the price for new ones are roughly 1300-1500 bucks. And there are still maybe a few more things you may want. And if your going for big power(ie direct port)you will be looking at a good amount more. And remember there is also the changing of spark plugs, some other little crap, and filling your bottle, usually about 40-50 bucks for a fill. Some of the above stuff will make that nitrous last a bit longer and save you a bit on buying the nitrous as much. This is just some of what ive learned from racing with me and my friends, which by the way all have nitrous, and one of them tunes F-Bodies and Vettes here in California, he knows what you should be getting, and we've talked about this several times.
It's not in your sig.
But go ahead and say, oh he doesnt even have nitrous he has no clue what hes talking about, because i see it coming. But like i said in the post above, a real reliable, safe, and more powerful kit does cost a good amount more than 300 bucks.
2) Purging lol.... I purge right into my intake during the burnout. That works a hell of a lot better than spraying nitrous out of your hood and clears the lines a hell of a lot better than the purge valve ever will.
3) What happens when you lose traction at the 100' mark and you need to get out of the bottle. With the WOT switch included in most "kits" you have to get out of the gas too and we all know that that is a dangerous proposition when the *** end is kicked out. It could easily cause a crash, whereas with a hand button you can just let off the button while still staying in the gas. The shock is less and you are less likely to lose control.
These "kits" are the worst thing to happen to Nitrous ever. They chock them full of superfluous crap that allows them to jack up the prices.
Store Manager: Candy Maginness
Phone Number: 727-822-1125
DARLENE WAS YOUR CASHIER TODAY.
RED BULL ENERGY DR 1.89 B
****TAX .27 BAL 4.05
Cash 20.00
CHANGE 15.95
11/07/04 8:07 PM 0028 06 0445 216
Where Saving Is
Part of the Pleasure.
THERES MY TIMES w00t
