Rather safe than sorry!
Old Nov 13, 2004 | 01:25 PM
ws6speedemon's Avatar
Default Rather safe than sorry!
What is the biggest shot I could run on my stock WS6? I have a few mods but nothing serious, just LS6 manifold and cutout... I've been told its ok to run like a 100 shot but some people say its pushing it and is better to run like a 75 shot... I want to run a 100 shot but I don't want to mess my car up... its the only one I have! Help me out guys, I want my nitrous!
Old Nov 13, 2004 | 01:33 PM
slow trap's Avatar
75 or 100 shouldn't be a problem at all.i have a 150 shot with a cam also.513 rwhp at 12:0 afr with stock pump.i know that is stretching it so i've got a racetronix pump to install soon.i used the 100 1 time and imediately put in the 150s and didn't look back.
Old Nov 13, 2004 | 01:35 PM
so maybe I should get the 150 shot, well, injectors for both 100 and 150 shot, then just to be extra safe get a different pump?
Old Nov 13, 2004 | 02:41 PM
GM Muscle's Avatar
If you go with a wet kit & fuel pump you should be able to go 150 no problem with stock tune and mostly stock motor. Just check your A/F ratio with a wideband, make sure your not detonating, and you sould be good to go. Make sure you swap your plugs and look into some saftey devices such as window switches, fuel pressure saftey switches and things like that.
Old Nov 13, 2004 | 02:43 PM
I was going to go all out, with the whole thing...
Old Nov 13, 2004 | 04:39 PM
GM Muscle's Avatar
That's the way to do it. It's not worth half assing it to save a few hundred bucks.
Old Nov 13, 2004 | 06:11 PM
Thanks a lot for the help guys, I'm sure once I actually get everything, I will be right back in here with more questions! Planning on having most of the stuff by the first of the year!
Old Nov 13, 2004 | 06:53 PM
the predator's Avatar
100-125 wet shot + a window switch(MSD) set to spray at 3k and shut off at 6k is extremly reliable from what ive been hearing. cant wait to get that setup myself.
Old Nov 13, 2004 | 08:30 PM
Thats what BlownFRC had when he was running nitrous, and it was completely reliable, cept he was running 150 shot... I think 100-125 will be all I need. or is it?
Old Nov 14, 2004 | 12:48 AM
DONAIMIAN's Avatar
ive been thinking about a 150-200 dry shot latley. And yes it is a daily driver.
Old Nov 14, 2004 | 12:06 PM
well the good thing about nitrous is you can turn it off...
Old Nov 15, 2004 | 12:00 AM
Well, I am looking into an NX wet kit... completely new in the box still froma private seller... anyone know where i can get a pod? tried looking for one, and can't find one!
Old Nov 15, 2004 | 12:47 AM
Formula1999's Avatar
Regards, does anyone know where can I get a full pillar with built in 3 pods for a 99 Formula HARD TOP?!
Thanks
Old Nov 15, 2004 | 01:10 AM
OnyxY2KSS's Avatar
Thanks
http://www.tbyrne.com/ls1catalog.html
GAUGES, all the way to the bottom...
Old Nov 15, 2004 | 01:15 AM
