Blow Down Requirements to pass Tech?
Old Nov 15, 2004 | 03:50 PM
BTLFEDSS's Avatar
Default Blow Down Requirements to pass Tech?
Just curious on what needs to pass tech can you run braided line instead of the tube and so on so any pics of how you have it set up if not using the tube.Does it matter where it exit as long as its out of the passenger compartment?
Thanx BTLFEDSS
Old Nov 15, 2004 | 06:44 PM
next's Avatar
Yes, braided line is a legal way to vent nitrous. I made a custom vent tube using 3/8" aluminum and flared an ACE hardware fitting on the end. Painted it the same as my car and voila.
Old Nov 15, 2004 | 07:27 PM
GM Muscle's Avatar
Here's a pic of mine. Just an -8AN 90*swivel hose end and some braided hose I had lying around. When you run it through the floor just make sure you put a hose clamp or something on the end (outside the car) so that the hose doesn't blow back throught the floor if the rupture discs pop.
Old Nov 15, 2004 | 07:31 PM
wbw2's Avatar
I cut mine off since the bottle lays sideways at a 45 degree angle, it wouldn't go straight out the bottom anyways. I put a compression nut on the tube end and then a barb hose adapter. Just a little heater hose and a clamp, and "voila", the tube is routed down through the hole in the trunk where the rubber plug was.(this is where my nitrous braided line exits also). DON'T forget to clamp the hose end on the outside of the car, or you'll end up with some serious water wiggle action!
Old Nov 16, 2004 | 12:18 AM
Elite_Hot_Rod's Avatar
I have dual bottles mounted right behind where the back seat used to be and I ran flexible AN10 hoses to the floor boards which connect to firewall fittings than pass thru the floor boards,no problem with tech.
Old Nov 16, 2004 | 04:11 PM
BTLFEDSS's Avatar
Thank You Evey One for the Help I Appricated The Info was Looking Forward of Spray at the Track.But just Found Out As Of 2005 IHRA Rules T top Cars Running Faster than 13.49 Need 6 point Cage which meens i Already Need One Guess thats The Next Mod before Hitting the Track Next Year
Thanx again BTLFEDSS
Old Nov 16, 2004 | 04:25 PM
LS1M's Avatar
According to the tech guy here in Houston, you don't have to use braided lines at all. A 5/8" heater hose is ugly, but passes tech. You clamp it over the whole blowdown fitting. I plan to replace it, though - looks ghetto.
There's a pic here:
http://www.ls1m.com/halo/halo.htm
Old Nov 16, 2004 | 04:40 PM
GM Muscle's Avatar
By the beginning of next season I think we'll see that change. It's pretty rediculous. You must hit NED? Street night tech seems pretty lax so I'm not even sure if they would enforce that, might see you over there in the spring.
Old Nov 16, 2004 | 04:46 PM
BTLFEDSS's Avatar
Yes i hit NED we'll have to meet up sometime next spring and shoot the **** i would like to see yor car in person it looks very nice in photos would like to see the new hood also hopefully they change the cage rule that $ could be used else where
Thanx BTLFEDSS
Old Nov 17, 2004 | 12:14 PM
Aries's Avatar
There's a pic here:
we've done that to pass tech... Only it was the power break vaccuume line off my car.
Old Nov 20, 2004 | 09:00 PM
BLK02WS6's Avatar
GM Muscle,
Thanks for the pic - that is exactly where I want to mount my bottle, so that helps. I'm gonna put a bulkhead/AN fitting through the floor with a line just like you did for the blowdown - looks nice!
Old Nov 21, 2004 | 09:18 AM
GM Muscle's Avatar
Glad I could help.
Old Jan 4, 2005 | 12:00 AM
Somebody09's Avatar
Oh now isn't that some horse ****! Too many goddamn dumb rules. I'm tired of wasting my money. I think I'll join the disgruntled street racers.
Old Jan 4, 2005 | 12:37 AM
chpmnsws6's Avatar
they say it every year and it never passes. they did say 11.50's till we need a cage this year
