Nitrous for the only mod?
Old Nov 17, 2004 | 03:57 PM
ROJO99's Avatar
Default Nitrous for the only mod?
Is this O.K. Just to have Nitrous with out the LT's.?
Old Nov 17, 2004 | 04:17 PM
hellbents10's Avatar
LS1Tech Sponsor
You might want to do a plug and wire change. Other then that you are ok.
TJ
Old Nov 17, 2004 | 04:26 PM
ROJO99's Avatar
Plugs, wires and injectors I can deal with. Do not know if I want to spend the 1 to 1.5K on a LT set up.
Old Nov 17, 2004 | 04:36 PM
Nitro Dave's Nitrous Outlet's Avatar
plug change and a wet system and your ready to go.
Old Nov 17, 2004 | 05:04 PM
DeepBlueZ's Avatar
you won't need injectors if you go with a wet kit or you spray a modest shot on a dry kit (125 or so.)
Old Nov 17, 2004 | 06:46 PM
wbw2's Avatar
I run a dry shot on stock manifolds, no problems at all. I have other mods though, but no LT's.
Old Nov 18, 2004 | 08:36 AM
koolrayz's Avatar
When i installed my dry kit my only mods were a lid, catback, nitto drag radials, LCA's and a panhard bar, ran a 12.15
Old Nov 19, 2004 | 09:03 AM
01Sidewinder's Avatar
I've had nitrous on my car for 2 years and sprayed about 50 10lb bottles with the only mod being a lid. That was a 100rwhp. After a couple months I did have to get a new clutch though. I made 315rwhp, 332rwtq motor and 413rwhp, 554rwtq nitrous. I haven't sprayed much since I got the cam, but those numbers are in the sig as well. All done with stock manifolds. The new numbers are with gutted cats and a cutout.
So all you need to change are the plugs (as long as staying w/ ~100hp shot). Have fun and be safe.
Old Nov 19, 2004 | 03:25 PM
NOTFAST's Avatar
I'm running a tnt wet kit on a stock car -- lid/ftra/exhaust -- no headers, no converter, stock tune, stock fuel...went 11.68 @ 120.5
