TNT 150 shot!
I heard that you should retard the timing like 1.5*
I am going to spray the 150 shot this weekend hopefully if the rain stays away. I just installed a vig 3200 and LCA's and a TA. I'm hoping for a low 11 or high 10!
The thing is, I still have a stock tranny and stock rear w/ 2.73's!
It should be fun. I'm just making sure the tune is going to be the best I can make it.
Thanks again guys
i agree 100%.its a wet kit! he doesnt need bigger injectors.i talked directly with Sam at TNT(very nice and helpful guy),and he said if your going to run a 150-shot...granted you have to buy the jets(kit comes w/75-125),he highly recommends a Walbro in-tank 255LPH fuel pump.
good luck! BTW i would get a Fuel Pressure Safety Switch, if you have an M6 get a window switch,bottle heater always helps.the gauge comes w/ the kit.definately put a fuse in-line w/ the power wire to the relay.
